Full Version: CBC TV (Canadian Broadcasting Corporation)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18
OK, fix was merged into the main plugins repo this morning. It should update on your systems soonish.
Not sure if your fix had anything to do with it but am now able to access Still Standing. If so thanks!
The CBC TV addon version 4.0.4 is now available.
With v4.0.4 I was able to get the listings for "The Great Canadian Baking Show" and also stream the "Chocolate Week" episode from Season 2.
With v4.0.3 I was unable to retrieve the listings.
Hence the issue @drew.b raised post 176 appears to be fixed.
Thanks for confirming.
Anyone else having trouble with this addon recently.  I know CBC changed some things on their end around Christmas.   Can access the cbc site from the web, but the addon get stuck when tyring to retrieve a show.
Version 4.0.4 still working fine with both live and recorded shows.
(2019-01-11, 02:03)Cangeoboy Wrote: [ -> ]Anyone else having trouble with this addon recently.  I know CBC changed some things on their end around Christmas.   Can access the cbc site from the web, but the addon get stuck when tyring to retrieve a show.
What problems are you having?
I was having problems with recorded shows.   It would get stuck with a message that it was trying to retrieve shows, then I'd get the addon error box.  However, this morning every thing is working fine again.  Problem solved Smile
Whenever I want to access a show the list is successfully retrieved. After clicking play it seems to be downloading the show and then throws an error to see the logs and nothing plays. Which log is referred to here?
The log Log file/Advanced (wiki) are you located in Canada?
Yes I'm located in Canada. It worked for a couple of times and now it will not start any show. I'll check logs tomorrow.
(2019-01-24, 07:40)190123 Wrote: [ -> ]Yes I'm located in Canada. It worked for a couple of times and now it will not start any show. I'll check logs tomorrow.
The very first post of this thread covers log posting.
I found the log entry and apparently it can't resolve. Which is weird as on my PC it all works without issue. Both are connected to the same router.
Quote:20:45:11.484 T:1886384896  NOTICE: CAESinkPi:AddPackets Underrun (delay:0.00 frames:2205)
20:45:16.923 T:1637872384   ERROR: CCurlFile::Stat - Failed: Couldn't resolve host name(6) for https://i.watch.cbc.ca/p/categoryThumbna...3a009c.jpg
20:45:16.925 T:1451373312   ERROR: CCurlFile::Stat - Failed: Couldn't resolve host name(6) for https://i.watch.cbc.ca/p/categoryThumbna...92529c.jpg
20:45:16.927 T:1261433600   ERROR: CCurlFile::Stat - Failed: Couldn't resolve host name(6) for https://i.watch.cbc.ca/p/categoryThumbna...2b2c0e.jpg
20:45:19.773 T:1278210816   ERROR: CCurlFile::Stat - Failed: Couldn't resolve host name(6) for https://i.watch.cbc.ca/p/categoryThumbna...3a009c.jpg
20:45:19.924 T:1451373312   ERROR: CCurlFile::Stat - Failed: Couldn't resolve host name(6) for https://i.watch.cbc.ca/p/categoryThumbna...92529c.jpg
20:45:20.076 T:1261433600   ERROR: CCurlFile::Stat - Failed: Couldn't resolve host name(6) for https://i.watch.cbc.ca/p/categoryThumbna...2b2c0e.jpg
20:45:25.241 T:1637872384   ERROR: CCurlFile::Stat - Failed: Couldn't resolve host name(6) for https://i.watch.cbc.ca/p/38e815a-00f6927...667177.jpg
20:45:25.243 T:1261433600   ERROR: CCurlFile::Stat - Failed: Couldn't resolve host name(6) for https://i.watch.cbc.ca/p/38e815a-00f4aa8...381809.jpg
20:45:25.244 T:1451373312   ERROR: CCurlFile::Stat - Failed: Couldn't resolve host name(6) for https://i.watch.cbc.ca/p/38e815a-00f486c...355718.jpg
20:45:25.370 T:1637872384   ERROR: CCurlFile::Stat - Failed: Couldn't resolve host name(6) for https://i.watch.cbc.ca/p/38e815a-00f360a...206043.jpg
20:45:25.370 T:1261433600   ERROR: CCurlFile::Stat - Failed: Couldn't resolve host name(6) for https://i.watch.cbc.ca/p/38e815a-00f3609...205974.jpg
20:45:25.372 T:1451373312   ERROR: CCurlFile::Stat - Failed: Couldn't resolve host name(6) for https://i.watch.cbc.ca/p/38e815a-00f3169...182091.jpg
20:45:25.373 T:1278210816   ERROR: CCurlFile::Stat - Failed: Couldn't resolve host name(6) for https://i.watch.cbc.ca/p/38e815a-00f486b...355462.jpg
20:45:26.257 T:1261433600   ERROR: CCurlFile::Stat - Failed: Couldn't resolve host name(6) for https://i.watch.cbc.ca/p/38e815a-00f855e...871400.jpg
20:45:26.259 T:1451373312   ERROR: CCurlFile::Stat - Failed: Couldn't resolve host name(6) for https://i.watch.cbc.ca/p/38e815a-00f3154...181968.jpg
20:45:26.259 T:1278210816   ERROR: CCurlFile::Stat - Failed: Couldn't resolve host name(6) for https://i.watch.cbc.ca/p/38e815a-00f310e...180310.jpg
20:45:27.457 T:1637872384   ERROR: CCurlFile::Stat - Failed: Couldn't resolve host name(6) for https://i.watch.cbc.ca/p/38e815a-00f3154...181968.jpg
20:45:27.459 T:1261433600   ERROR: CCurlFile::Stat - Failed: Couldn't resolve host name(6) for https://i.watch.cbc.ca/p/38e815a-00f310e...180310.jpg
20:45:28.590 T:1278210816   ERROR: CCurlFile::Stat - Failed: Couldn't resolve host name(6) for https://i.watch.cbc.ca/p/38e815a-00f6927...667177.jpg
20:45:28.592 T:1637872384   ERROR: CCurlFile::Stat - Failed: Couldn't resolve host name(6) for https://i.watch.cbc.ca/p/38e815a-00f4aa8...381809.jpg
20:45:29.194 T:1451373312   ERROR: CCurlFile::Stat - Failed: Couldn't resolve host name(6) for https://i.watch.cbc.ca/p/38e815a-00f6927...667177.jpg
20:45:34.498 T:1925904896  NOTICE: VideoPlayer: Opening: https://cbcvott-a.akamaihd.net/p//38e815...1548470732~
20:45:34.498 T:1925904896 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
20:45:34.687 T:1294988032  NOTICE: Creating InputStream
20:45:35.786 T:1294988032  NOTICE: Creating Demuxer
20:46:06.066 T:1294988032   ERROR: OpenDemuxStream - Error creating demuxer
20:46:06.067 T:1294988032  NOTICE: CVideoPlayer::OnExit()
20:46:06.068 T:1925904896   ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.cbc/?image=https%3A%2F%2Fi.watch.cbc.ca%2Fp%2F38e815a-00f69271ab5%2FCBC_BARONESS_SKETCH_SHOW_SEASON_03_S03E10-v2-18667177.jpg&labels=plot%3DAn%2Bunwanted%2Bgift
20:46:06.069 T:1925904896  NOTICE: CVideoPlayer::CloseFile()
20:46:06.069 T:1925904896  NOTICE: VideoPlayer: waiting for threads to exit
20:46:06.069 T:1925904896  NOTICE: VideoPlayer: finished waiting
20:46:06.070 T:1925904896  NOTICE: CVideoPlayer::CloseFile()
20:46:06.070 T:1925904896  NOTICE: VideoPlayer: waiting for threads to exit
20:46:06.070 T:1925904896  NOTICE: VideoPlayer: finished waiting
It is able to retrieve the show list successfully.
Please just post a link to the logs. Those lines are red herrings.
The log can be found here
