Full Version: CBC TV (Canadian Broadcasting Corporation)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37
Are you in Canada
(2021-01-12, 02:43)barney63 Wrote: [ -> ]Are you in Canada
I am, about 30 miles south-ish of Front Street in the t-dot
What happened to CBC TV, I don't see it in kodi addons anymore.
I am seeing Canadian Broadcasting Corporation (CBC) in both Matrix and Leia 18.9 (and it is working for me).  What I'd like to see is the former CBC Sports addon back and working Smile
(2021-01-25, 05:39)barney63 Wrote: [ -> ]I am seeing Canadian Broadcasting Corporation (CBC) in both Matrix and Leia 18.9 (and it is working for me).  What I'd like to see is the former CBC Sports addon back and working Smile
I have CBC TV working for me too on Matrix, but when looking thru the addons in KODI repo I noticed it's not there. Why removed?
I miss CBC sports to and I believe it's in Metalchris repo. I don't believe he supports it anymore and also he has not moved any addons to Matrix.
(2021-01-25, 19:50)rocko Wrote: [ -> ]I have CBC TV working for me too on Matrix, but when looking thru the addons in KODI repo I noticed it's not there. Why removed?
One of us must be misunderstanding something.  I am seeing it in the Kodi Repo in both Matrix RC1 and Leia 18.9. It's under Canadian Broadcasting Corporation (CBC) not CBC TV.
(2021-01-26, 00:55)barney63 Wrote: [ -> ]
Rite I am talking about Canadian Broadcasting corporation.
It is in the KODI repo in Matrix and Leia otherwise I couldn't have loaded it.
What I'm saying is where all the addons are listed on the KODI site in video addons only CBC Olympics AND CBC.ca News are listed.
No big deal just wondered why missing there.
Anyway wish there was a way to add this to IPTV simple client with guide  like thru like IPTV Merge
Not able to pull shows in today, just live feeds
2021-08-17 21:52:21.896 T:87414   ERROR <general>: plugin.video.cbc: (getShows) None returns 426 status
2021-08-17 21:52:21.911 T:87414   ERROR <general>: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                                   Error Type: <class 'TypeError'>
                                                   Error Contents: 'NoneType' object is not subscriptable
                                                     File "/home/david/.kodi/addons/plugin.video.cbc/default.py", line 249, in <module>
                                                       showsMenu(values)
                                                     File "/home/david/.kodi/addons/plugin.video.cbc/default.py", line 178, in showsMenu
                                                       isVideo = True if 'video' in show_list[0] else False
                                                   TypeError: 'NoneType' object is not subscriptable
2021-08-17 21:52:21.990 T:87414    INFO <general>: Python interpreter stopped
2021-08-17 21:52:21.992 T:87413   ERROR <general>: GetDirectory - Error getting plugin://plugin.video.cbc/?menu=Shows
2021-08-17 21:52:21.993 T:87371   ERROR <general>: CGUIMediaWindow::GetDirectory(plugin://plugin.video.cbc/?menu=Shows) failed
2021-08-17 21:52:21.994 T:87417    INFO <general>: initializing python engine.
2021-08-17 21:52:22.470 T:87417 WARNING <general>: xbmc.translatePath is deprecated and might be removed in future kodi versions. Please use xbmcvfs.translatePath instead.
2021-08-17 21:52:22.511 T:87417    INFO <general>: Skipped 1 duplicate messages..
2021-08-17 21:52:22.511 T:87417    INFO <general>: CPythonInvoker(7, /home/david/.kodi/addons/plugin.video.cbc/default.py): script successfully run
2021-08-17 21:52:22.582 T:87417    INFO <general>: Python interpreter stopped
2021-08-17 21:52:38.659 T:87371    INFO <general>: Loading skin file: Settings.xml, load type: KEEP_IN_MEMORY
2021-08-17 21:52:41.476 T:87371    INFO <general>: Loading skin file: SettingsCategory.xml, load type: KEEP_IN_MEMORY
2021-08-17 21:52:42.143 T:87371   ERROR <CSettingInt>: unknown options filler "libinputkeyboardlayout" of "input.libinputkeyboardlayout"
EDIT: tried uninstalling Kodi and reinstalling with new profile...no luck
(2021-08-18, 04:01)SpottedDog Wrote: [ -> ]Not able to pull shows in today, just live feeds
I can confirm, Live Channels working ok, Shows brings up error.
Olympic Channel has reappeared.
CBC v4.0.7+matrix.1 became available today and lists and plays shows for me on Kodi Matrix 19.1.
(2021-08-21, 20:41)kodaksmith Wrote: [ -> ]
(2021-08-21, 20:41)kodaksmith Wrote: [ -> ]CBC v4.0.7+matrix.1 became available today and lists and plays shows for me on Kodi Matrix 19.1.
Not seeing this version in the Kodi repository as of yet. Not sure if it is because I am running Linux or there is a delay before it reaches me
Working now on my Linux PC but not yet on my Corelec Arm device. Thanks for continuing   work on this  Micahg
Working again on my Windows, thanks.
Hi Micah,
Are you planning on releasing the 4.0.7 update for Leia as well?
I still have several Raspberry Pi devices "stuck" on Kodi 18.9
For some reason this does not seem to update on my Odroid N2 Coreelec device running Kodi 19.1.
EDIT: Sorry my mistake the odroid is on Kodi 18
