2018-02-12, 22:41
Hi have a little problem with my kodi installation on htpc since i had to drop the Kodi-openbox to upgrade to Leia and ubuntu 17.10
Kodi autostart now with a fxce ~/.config/kodi.desktop script, and I disabled the login prompt with lightdm. But since then, I can't go back to the fxce GUI, Kodi keep restarting. And if a do ctrl+alt+f1 to go to CLI, I can't startxfce4.
But my htpc is set to be portable so I need to be able to go back to GUI to connect to new wifi networks.
I have the knowledge in Linux to build my htpc from a minimal ubuntu, but it's thin and after long hours looking for a solution, I need help to figure out the problem and solve it.
Thank you for reading me and for the help you could maybe provide.
