Full Version: Apple Trailers won't play
I loaded the newest (at the time) T3CH build with a regular old television and had no problems. Yesterday I bought an HDTV and ran the xbox HD component cables and everything looked great. However when I attempted to play movie trailers it would load them but never play them. After the loading window closed I was back to the regular AMT menu although the trailer i had selected was grayed out as if it played.
I reloaded XBMC and ran into the same problem again although this time I received a "playlist playback aborted too many consecutive failed items" error message. On occaision while loading an audio codec the entire operation will freeze up and i have to restart the xbox.
I'm not really sure where to begin? Maybe an older version of AMT?
AMT version pre-0.99.4a-2091
XBMC T3CH build SVN_2008-04-20_rev12746
Xbox V 1.0
All help is greatly appreciated
HMLJ
you're running out of memory.
1. try the plugin, you install it from AMT settings.
and/or
2. make sure your gui and video resolution is not 1080i. 720p should work
I did both. Seems to be running ok now. Thank you.
