2019-02-13, 17:24
(2019-02-12, 01:41)Tired Dad Wrote: [ -> ]Hello, thank you for making a great skin while we wait for Arctic Zephyr 2I am also having this issue. Love the skin and would love to use it but I need to figure out what is causing this. I have tried fresh install and with multiple different skins. The auto-log into masterprofile after logging off another profile is only happening with Aura skin. I have searched in several xml files for the skin but can not find anything that would be causing this. 1 other thing is it does not automatically log into the master profile when first starting Kodi or when logging off the master, just when you log off with another user. Any help would be greatly appreciated.
I have noticed something odd with multiple profiles and this skin. Every time a user profile exits, the master user is loaded, even if the master user has an unlock code. This behaviour is repeatable with two or more profiles and it does not matter if the profiles have lock codes or not. Changing the master user ID to 99 in the profiles.xml did not work, it still loadd the master.
This can be an issues because the master user is completely open from an admin POV and also the library is separate from the one I have for the kids, so it's a concern from a library accessibility standpoint as well. This is occurring on the Leia version of the skin. Changing the users to other skins results in the issue disappearing. I'm not sure if this is affecting anything, but whenever I add a new user, they cannot load the skin (or any skin for that matter) from the interface menu, I have to go to the add-ons to install it.
Has anyone experienced something similar? Uninstalling the profiles and reinstalling did not work, nor did the brute force method of deleting the profiles folder. The nuclear option of uninstalling Kodi didn't resolve it either.
Thanks for any advice you may have.
TD
Thanks for the great skin otherwise.
