Can anyone point me in the right direction to get the Oscars information given please. I am using Artowrk Beef I think i have every option enabled but i do not see any Oscar info in the Extended Info view.
(2019-02-16, 06:15)Blurayx Wrote: [ -> ]@jurialmunkey
I see you have updated Aura to 1.0.4 on GitHub but Kodi is showing 1.0.2. is this correct?
Repo version: 1.0.2
Git: 1.0.4
You need to do manual update for last gits changes
(2019-02-16, 16:45)Mr Cellophane Wrote: [ -> ]Can anyone point me in the right direction to get the Oscars information given please. I am using Artowrk Beef I think i have every option enabled but i do not see any Oscar info in the Extended Info view.
need to install skinhelper
Hi there love the skin. Is there a way to disable the extended info button or addon? I have an Nvidia Shield and it always take a long time to load, like 10 seconds. If I can disable it completely that would be great.
thanks I have enabled that now but still no joy on the Oscars details - any thoughts please? I seem to get everything else but the Oscar info.
(2019-02-16, 20:54)chrissix Wrote: [ -> ] (2019-02-16, 16:45)Mr Cellophane Wrote: [ -> ]Can anyone point me in the right direction to get the Oscars information given please.
Do you mean like this:
https://ibb.co/Ph4Lm5f
https://ibb.co/Sccr43C
https://ibb.co/VLTXs1F
I am not sure if this skin supports this at all.
Yes the skin does support showing the number of oscars. Please see first post of this thread for details about how to setup skin helper with an omdb api key.
First of all : The Skin is amazing
Great work.
Netflix Widget is not working . After reboot the widget is empty . Any fix for this ?
(2019-02-16, 13:16)djoole Wrote: [ -> ] (2019-02-16, 02:05)jurialmunkey Wrote: [ -> ] (2019-02-16, 00:08)djoole Wrote: [ -> ]Hey @jurialmunkey would it be possible for you to add the end time in OSD? I loved this option in Fuse!
Press Info on remote and it will show.
It's present in the info screen from the library views, but not present in the info screen in the player.
NB : i use the shield remote, so to display the info i call the OSD (OK button) then extend it (UP button).
Up for that. Am I missing something?
If the end time is indeed not present in Info from player, @
jurialmunkey would you be willing to add it please?
(2019-02-17, 12:39)djoole Wrote: [ -> ] (2019-02-16, 13:16)djoole Wrote: [ -> ] (2019-02-16, 02:05)jurialmunkey Wrote: [ -> ]Press Info on remote and it will show.
If the end time is indeed not present in Info from player, @jurialmunkey would you be willing to add it please?
Ah, yeah you need a dedicated info button to see it because otherwise the osd controls are in the way:
Maybe you can map long press OK to the info command?
I can't, long press OK is map to contextual menu and this function is vital
I have an idea, when the info screen is called during playback (up button from OSD), could you make the OSD controls disappear? And reappear when down button is pressed.
Weird think with icons on submenus, majority of addon icons are square yet they are stretched when added to a sub menu/category.
I've also created alot of custom icons that I like to use throughout my build and again these are square about 133px square in size. But when I change the icon in category menu and go back to the homescreen it too is stretched out of proportion.
When I go to actually change the icons it shows up in the custom home page menu and it looks perfect, just not in the actual home menu.
jurialmunkey , are there any plans to support the views that are in the
Advanced Emulator Launcher Estuary skin? Such as ROM Simple, ROM MAME, ROM Console, etc. I tried ported the view xml from github into a local instance of your repo and (to me at least) it was not a trivial port at all. Lots of nested
include blocks made it tough to figure out how to merge it into your style.
(2019-02-17, 13:27)djoole Wrote: [ -> ]I can't, long press OK is map to contextual menu and this function is vital
Yeah this might be a possibility.
BTW you can map buttons on a per window basis (ie only in fullscreenvideo) - I'm pretty sure long press OK is mapped to play/pause on fullscreenvideo by default.
Before I upgrade to Kodi v18, I'm looking into a fitting Skin, and this one might be it. Just a few questions beforehand:
Does Aura support custom home menu entries as well as custom images for those entries (pretty much like Arctic Zephyr does)?
