im New one here. and i have a question where i can find the update skin. i still have 1.0.2
Hello,
Does anyone know why the Search function don’t work in this skin? I can typ in a word, but there is no results. And I know I have what I search for in my library?!
(2019-12-20, 09:57)Uatschitchun Wrote: [ -> ] (2019-12-01, 05:38)AbRASiON Wrote: [ -> ]Guys I have a strange request.
Can I add a front page entry which shows "recently added TV shows"
Not "recently added episodes" but actual shows? Is this possible?
Have you tried creating a node or a smart playlist that displays what you'd like to have and set that as widget?
Do you think a smart playlist could actually do that? I am more than willing to give it a shot if you think it can be done.
(2020-01-01, 03:00)AbRASiON Wrote: [ -> ] (2019-12-20, 09:57)Uatschitchun Wrote: [ -> ] (2019-12-01, 05:38)AbRASiON Wrote: [ -> ]Guys I have a strange request.
yepp.pretty simple.
just create a list of shows with descending date added order.
you can for sure limit them or set some other rules.
here a simple example without any specisl rules.
xml:
<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
<smartplaylist type="tvshows">
<name>new series, no limit </name>
<match>all</match>
<order direction="descending">dateadded</order>
</smartplaylist>
(2020-01-02, 20:38)Nazgulled Wrote: [ -> ] (2019-12-02, 13:23)Nazgulled Wrote: [ -> ]This skin is lovely but there's one very annoying thing that I can't seem to find a way to disable, the startup sound. How can I turn it off?
I can't seem to find any skin option in the GUI to turn it off nor I can't seem to find a sound file inside the "skin.aura" folder relative to this.
Any ideas?
Any one?
Nevermind, it was my issue with the GUI Sounds I have installed.
Hi @
jurialmunkey Artist Slideshow not working properly with you skin.
(2020-01-05, 06:41)roliverosc Wrote: [ -> ]Hi @jurialmunkey Artist Slideshow not working properly with you skin.
I tried modifying the skin without prevail. If you install version 2.7 ArtistSlideshow it works just fine. Version 3.0 has changes that a lot of skins don't work with yet, including the default skin.
(2019-12-08, 15:41)ray2301 Wrote: [ -> ]regarding artist slideshow, does anyone know what changes need to be made to aura for this to be implemented?
https://forum.kodi.tv/showthread.php?tid...pid2905238
to answer myself, i found it. it's actually not musicvisualisation.xml that needs changes for it to work properly in aura, but includes_images.xml
took a while, but ended up being a very small and simple change.
if anyone else will be searching - this part needs to be replaced in includes_images.xml:
Quote:Code:
<variable name="Image_ArtistFanartVis">
<value condition="!Skin.HasSetting(ArtistSlideShow.Disabled) + !String.IsEmpty(Window(Home).Property(SkinHelper.Player.Art.ExtraFanArt))">$INFO[Window(Home).Property(SkinHelper.Player.Art.ExtraFanArt)]</value>
<value condition="System.HasAddon(script.artistslideshow) + !Skin.HasSetting(ArtistSlideShow.Disabled) + !String.IsEmpty(Window(Visualisation).Property(ArtistSlideshow.Image))">$INFO[Window(Visualisation).Property(ArtistSlideshow.Image)]</value>
<value condition="[!System.HasAddon(script.artistslideshow) | Skin.HasSetting(ArtistSlideShow.Disabled)] + Skin.HasSetting(musicvis.fanartfallback) + !String.IsEmpty(Player.Art(fanart))">$INFO[Player.Art(fanart)]</value>
<value>common/null.png</value>
</variable>
Hi all,
I have my own video addon that I am trying to amend to use with Aura (I'm using Auramod, but its based on this skin I think). I'm still a noob with these things but I can't figure out how to style the video info dialog:
I am using a widget, playing a movie directly from there but this info screen above is pretty much empty (missing poster, year, genre, plot, stars etc.)
I am creating list item objects and tried to do this as a test but it doesn't work:
list_item = xbmcgui.ListItem(label, iconImage=thumb, thumbnailImage=thumb)
list_item.setArt({ 'poster': thumb, 'banner' : thumb, 'icon': thumb, 'thumb': thumb, 'fanart': thumb, 'clearart': thumb, 'clearlogo': thumb, 'landscape': thumb })
Info is set like this:
list_item.setInfo('video', {'title': list_item.getLabel(), 'plot': plot, 'mediatype': "movie", 'rating': rating, 'year': year})
Can someone help? Thanks
Hey all. First thing to note I'm stuck on Krypton because I'm using an apple tv 4k. So this might be my issue but here's my problems. Currently all my genre info for tv and movies is "other" instead of what it should be. Secondly I can't get RT ratings to work even though I have skin helper 1.1.24 and all the appropriate API keys. Any ideas?
Hello,
is it possible to change player setting ?
as french i download lot of multilanguage content and audio setting is hidden very far away in player.
Best regards,
Love this light and nice skin keep on the good work please and thank you !
Why do i get asked for a PIN (Netflix) just while i hover over a Video?
Thank you @
ray2301 - the fix seems to work fine. Too bad that this great skin seems to be abandoned. Love the looks and the customizability of it.
Silvayn I don't think jurialmunkey has abandoned Aura. His focus has been on AZ2. I remember him posting that he as plans for Aura when AZ2 is done. I hope that has not changed. I try AZ2 From time to time but Aura is the best fit for us.
