Full Version: Aura
Hi!
At first, sorry for my English.
I have some trouble with such thing as "Auto close OSD controls after delay (in seconds)".
It worked great, but from some moment it stoped. I can't understand why. Now OSD is not close automatically with any number of seconds in this field. I can hide it only with a button on remote control.
I tried to restore settings, clean data, re-installing Aura and even whole KODI, but this don't help.
Can anybody help with this?
Maybe there is some another settings, which conflicting wiht this one, and I need check them?
At least, tell me please, where can I find this setting in folders and files to try check it in manual.
Dear Sir, Thank you for your work, Kodi Skin Aura is great for me!
I have a question: on the "Power" menù, can i put "Exit" before "reload skin"? I'll try but i can't be able to do it.
Thank you in advance.
nicolap
What tricks I have to do to make this skin show episode/movie audio format (DTS/DD/AAC/etc..) in the description/info section while scrolling thru library?
Answer is: "Skin Settings > Library > Show media flags instead of ratings in library views."
Hi @jurialmunkey
Thanks for the great skin.
I am new to this skin, I am already loving it.
I have few doubts...
1. Any option to set the size of poster to "Small poster" in home screen widgets (like in Titan mod skin) on my 55 inch TV posters look very big.
2. Any future plans for Netflix like view type?
3. Trakt rating popup not appearing after finish watching a movie, is there any special setting? (working well in my Titan mod skin)
4. Any way to get "Finishes at:" time display on player osd without pausing the video? (it is displayed when playback is paused)
Please take time to clarify these...
Thanks in advance.
Do I need to do something to get the rotten tomato ratings to show up? It has IMDb and MovieDb but nothing from RT. I am using the skin with plexkodiconnect if that matters. Is there an addon that I am missing? Thanks.
(2020-05-03, 20:17)Deihmos Wrote: [ -> ]Do I need to do something to get the rotten tomato ratings to show up? It has IMDb and MovieDb but nothing from RT. I am using the skin with plexkodiconnect if that matters. Is there an addon that I am missing? Thanks.
Do you have skinhelper insttaled?
(2020-05-03, 20:26)Edworld Wrote: [ -> ]
Yes I do. I didn't realize there is some info on the first page that I did not review.
What is the purpose of the next aired plugin related to the skin? I don't see a widget and I can't seem to do anything with it. Am I missing something?
Good night everyone, I'm new here.
I would like a help to add widget on an item in the home.
I wanted you to open the list of channels of my PVR in the widget of that item on the home screen.
I thank you for your help.
Is there a possibility to change the video player?
I don't get used to this one, I think bglistplayer is much better.
If this possibility exists, can someone explain how to do it?
Thanks for listening
Hi at all
First thanks for the Great work and an incredible Skin.
I have a question about the player.
The Player shows info. Name of Episode and Poster when paused if you set it correct in the skin settings.
Is there also a way to show the info at start of a Video or Episode?
http://imgur.com/a/Fsk82Hn
 imitation is the highest form of flattery. Check out the latest redesign of Hulu (Upper image) vs the Aura skin I've been using for a year now(lower image). Really close, right?
Imitation is the highest form of flattery. Check out this, the upper image is from the new Hulu redesign, the lower image is the Aura home I've been using for about a year now. Really close, right?
It's even closer to Arctic Zephyr 2, they even added the Search option top left:
Hi Guys,
the last days i had problems with my internet provider and no internet connection and in this time my Kodi 18.7 on Win 10 64 with Aura skin won´t start at all.
If I start Kodi it stucks everytime in the Aura startscreen an shows initialising skin with running spinner. I´ve tested it many times but can´t get it to work.
I connected my HTPC to my mobilephone internet and start Kodi again, and Kodi starts normaly. Then I recheckes it without internet and it stuck again in startscreen. The Standart skin works with or without internet.
Is there a way to get Aura running without internet?
Please Help
Markus
