(2021-03-13, 04:24)kcook_shield Wrote: [ -> ]New MOD for this skin to run on Matrix is available for those wanting to test:
https://github.com/kcook98765/skin.aura
I have made basic changes to get this to load under Matrix (and am using it as I like this skin).
I'll try to clean up code, fixes things that don't work and maybe some feature additions (once I get more familiar with skinning).
Enjoy!
Thank you! I didn't want to upgrade Kodi because I love Aura so much. I've just installed them both and it is working. So again, thank you.
(2021-03-16, 01:00)kcook_shield Wrote: [ -> ] (2021-03-14, 18:07)Zpower Wrote: [ -> ]@kcook_shield already test your mod
I've a little problem...
Posters don't display on tv-shows but work ok on movies.
Any idea?
I tried a fresh kodi install, then installed this skin and I am seeing posters as expected.
There maybe something else going on that I just can't see yet. Perhaps a log file from you would help.
Are you using any special addon to handle resources like posters, etc?
Hello
I don't know if you understand what i said...(probably my bad english)
That problem only occurs on posters of TV-Shows.
Posters of Movies display normal.
I make what you suggest (clean installation of kodi 19 and your aura mod) no settings made. Only kodi+aura
Only Scraper shows and the results are the same. No posters!
LOG HERE (
https://paste.kodi.tv/boxogobohu.kodi)
On the other hand, i test old version of Kodi (18.9 Leia + Original Aura skin) and everything works normal.
(2021-03-17, 20:37)Zpower Wrote: [ -> ] (2021-03-16, 01:00)kcook_shield Wrote: [ -> ] (2021-03-14, 18:07)Zpower Wrote: [ -> ]@kcook_shield already test your mod
Any idea?
Hello
I don't if you understand what i said... That problem only occurs on posters of TV-Shows.
LOG HERE (https://paste.kodi.tv/boxogobohu.kodi)
I have same issue, tried to run artwork addon and it still didnt fix, Did end up with a bunch of extra fanart and stuff though. No posters on TV shows confirmed. Still glad to see the Aura alive on Matrix. This skin has so many positive things going for it. Its nice, clean, highly customizable, and works great. Also when i went to customize home screen , it took the change, but then locked me out , I cant get back in to edit again. Invalid link or something.
I was able to duplicate the missing posters and some other errors. Will be working on fixes and post an update when ready to test a newer version.
(2021-03-20, 09:20)Zpower Wrote: [ -> ]Clean install, dependencies like you describe one by one and next your mod.
Some work not totally fix.
But thanks for your work.
Here's the log if you want to analyse something https://paste.kodi.tv/agiqupufun.kodi
Thank you for testing.
Am still dissecting the code to figure out all the little details, like missing images etc are and how to adjust the skin to get them displayed. Hope to have images fixed up within a few days.
I have more of the Posters working now (the Big posters especially). Seems some smaller posters in some views are not displaying, so a bit more work to do still, but big improvement now.
My repository has the recent changes available now.
Hello, I have Aura Mod and I have a problem if you can help me.
I want to put an intro video at startup, I have activated the intro video option in skin / miscellaneous settings.
The mp4 video I have placed in the Media folder named introxxxxx.mp4, when Kodi starts the video plays but at the end it remains a gray screen and for the menu to appear I have to press backspace, what could it be due to? Thank you
(2021-03-23, 00:35)Carfer Wrote: [ -> ]Hello, I have Aura Mod and I have a problem if you can help me.
Tested and saw similar issue. Made some changes and it now seems to function as expected.
You could try updating the skin from my repository (download the zip, and "add" it in settings to get it updated).
(2021-03-23, 02:47)kcook_shield Wrote: [ -> ] (2021-03-23, 00:35)Carfer Wrote: [ -> ]Hello, I have Aura Mod and I have a problem if you can help me.
Thank you very much for the help, where can I see the repository?
(2021-03-23, 17:43)Zpower Wrote: [ -> ] (2021-03-23, 11:10)Carfer Wrote: [ -> ] (2021-03-23, 02:47)kcook_shield Wrote: [ -> ]Tested and saw similar issue. Made some changes and it now seems to function as expected.
Thank you very much for the help. I have 2 doubts about it.
Is this repository modification for Matrix 19 or is it also valid for 18.9? I say this because it gives me an error when installing.
And the other question is, if I install the mod and first save the skinshorcuts and skin aura mod folders that are inside userdata to preserve all my build configuration, would it leave me the menu the same as I have it now or would I lose everything?
Thanks a lot
