(2021-03-28, 16:34)Sjors125 Wrote: [ -> ]Am I correct that Aura isn't in the Kodi 19 matrix repo?
I wanted to add this marvellous skin to my new chromecast with google tv, but it wasn't in the list
If you spend some time reading posts before yours you will discover some information.
Don't be so lazy 😉
(2021-03-28, 22:41)Zpower Wrote: [ -> ] (2021-03-28, 16:34)Sjors125 Wrote: [ -> ]Am I correct that Aura isn't in the Kodi 19 matrix repo?
Don't be so lazy 😉
Please stop assuming
I've read the OP and I've used google and the forum search for aura + repo + matrix (and other combinations) and found no solutions to my question
I did found a jurialmunkey repo in older skins, but as it wasn't mentioned in the OP, so I don't know if I need that for this skin too.
I did not know this skin is not supported/continued anymore (just read that a few pages back). Hard to use the right search queries then
(2021-03-28, 23:49)Sjors125 Wrote: [ -> ] (2021-03-28, 22:41)Zpower Wrote: [ -> ] (2021-03-28, 16:34)Sjors125 Wrote: [ -> ]Am I correct that Aura isn't in the Kodi 19 matrix repo?
Don't be so lazy 😉
Use the matrix mod here
https://github.com/kcook98765/skin.aura
It's good enough for you love this skin
Thanks Zpower! I will check it out!
(2021-03-29, 08:36)Zpower Wrote: [ -> ] (2021-03-28, 23:49)Sjors125 Wrote: [ -> ] (2021-03-28, 22:41)Zpower Wrote: [ -> ]If you spend some time reading posts before yours you will discover some information.
Don't be so lazy 😉
Use the matrix mod here https://github.com/kcook98765/skin.aura
Love this skin! Absolutely my favorite. But how can I update it? Is it enough to load new zip from repository on top of currently installed skin?
(2021-03-29, 16:58)nfm886 Wrote: [ -> ] (2021-03-29, 08:36)Zpower Wrote: [ -> ] (2021-03-28, 23:49)Sjors125 Wrote: [ -> ]Please stop assuming
Go to the link
https://github.com/kcook98765/skin.aura and at the bottom read how to but basically its install all the dependencies and next the zip of mod
(2021-03-26, 20:05)kcook_shield Wrote: [ -> ]While I will try to work out more fixes, I doubt I will get everything fixed to the point of original functionality of this skin.
jurialmunkey (the one that originally built Aura skin) has a newer skin that looks great and I may switch to start using it myself.
It is Arctic Horizon, details about it and how to install:
https://forum.kodi.tv/showthread.php?tid=351756
I found that I could switch the skin layout to horizontal (default is vertical) and then layout is similar to Aura (though with better and much more feature rich options).
Also, it will soon be in official Kodi repo so that it would be readily maintained/updated and easier to install.
I would strongly advise at least looking into this skin as a replacement for Aura.
Yeah i’ll ready try it, but it's not the same thing...
Your mod its functional so ill continue using.
In the future if you make some fix all community of aura will be very appreciated.
Thanks again.
(2018-02-16, 03:09)jurialmunkey Wrote: [ -> ]1. Install the beta version of skin helper from marcelveldt's beta repository (and update all relevant dependencies e.g. metadatautils and simplecache).
https://github.com/kodi-community-addons...-1.0.1.zip
this path is 404 now
I checked the home page to see if it had been updated but its also pointing to the dead link
(2021-05-02, 10:06)alexbelgium Wrote: [ -> ]?? How to edit a post?
Select EDIT, then pick one of FULL EDIT or QUICK EDIT
(2021-05-02, 11:04)0ldfart Wrote: [ -> ] (2021-05-02, 10:06)alexbelgium Wrote: [ -> ]?? How to edit a post?
Thanks! It seems I need to post more before being able to edit (
https://forum.kodi.tv/showthread.php?tid=342174)
As a follow-up I've tested all versions and settled on kcook's, that's the most polished and complete in my opinion...
(2021-05-04, 22:29)alexbelgium Wrote: [ -> ]As a follow-up I've tested all versions and settled on kcook's, that's the most polished and complete in my opinion...
Do RT and Metacritic ratings work? I note that they are using the kodi repo version of metadautils...
(2021-05-05, 06:16)0ldfart Wrote: [ -> ] (2021-05-04, 22:29)alexbelgium Wrote: [ -> ]As a follow-up I've tested all versions and settled on kcook's, that's the most polished and complete in my opinion...
No. I think need some coding to work again with the new metadautils.
I've reported yet to @
kcook_shield  but i don't think will be some developing.
