(2021-05-13, 01:55)kcook_shield Wrote: [ -> ] (2021-05-12, 17:10)Zpower Wrote: [ -> ] (2021-05-12, 02:29)kcook_shield Wrote: [ -> ]I believe I found the issue in the skin for ratings display for movies.
I have updated the repo skin, download and load into kodi and it should work now.
Just tested and don't work for me.
Same scenario of your previous git and my last post. (No votes or nether rotten and metacritic ratings on movies)
i create a new source of my movies and create a new simplecache to force populate database but don't work
I'm glad you fix some other things like dialogaddon.xml
Not sure why it is not working for you. I did find a couple minor issues, so there is another version now available in my github (but this only fixes some specific ratings displays, even though I was/am getting ratings myself).
Perhaps try the new version, if still having issues, another entry from the simplecache DB might be useful for me to verify some things.
Note, recent couple of changes to the skin involved changing the skinhelper "names" for the fields where ratungs are stored (pre Matrix, it seems names were different).
Now works!
I just understand what's happen!
In settings of AURA there are a option "Show Media Flags instead of Ratings in library views" IF we have this option ON Ratings of Rotten and Meta dont show up only IMDB. IF OFF show ratings and votes.
NOTE: You can view simplecache.db with DB Browser for SQLite to understand all strings require.
Thanks for your work
(2021-05-13, 17:05)Zpower Wrote: [ -> ]Now works!
Did a fresh install according to instructions on github. Ratings not working here.
Hi everyone, from arthic I am a lover of companion skins, just now I have updated to kodi matrix and I want to try Aura. I have read the first post and some more (not the 146 pages of the post), and it is not clear to me which version to install in order to have Aura from the repository so that it can be updated.
You have to install the one from this link that I put or is it another? Thanks.
https://github.com/jurialmunkey/skin.aura --> This or other?? Very thanks.
(2021-06-22, 15:06)jojobro Wrote: [ -> ] (2021-06-21, 12:22)Maximo86 Wrote: [ -> ]Hi everyone, from arthic I am a lover of companion skins, just now I have updated to kodi matrix and I want to try Aura. I have read the first post and some more (not the 146 pages of the post), and it is not clear to me which version to install in order to have Aura from the repository so that it can be updated.
This is the RUN DOWN on Aura and AuraMod:
Original Aura was made by jurialmunkey @ https://github.com/jurialmunkey/skin.aura !!!which has since been abandoned.
Aura v19 is being updated by kcook98765 over at @ https://github.com/kcook98765/skin.aura !!!WIP but funtional.
AuraMOD was originally created by skyfsza @ https://github.com/skyfsza/skin.auramod !!!but has been abandoned.
AuraMOD v19 is being updated by SerpentDrago(and others) @ https://github.com/SerpentDrago/skin.auramod !!!WIP but funtional.
repo @ https://github.com/SerpentDrago/repository.auramod.aio
MAKE SURE: to follow the bottom sections of either for the install pre/post instructions. They are pretty specific.
Thank you very much for the summary of versions, everything has been super clear to me. I think I will install auramod, thank you again.
Is there anyway to get artist slideshow working with AuraMOD v19?
For some reason, on LibreElec 10.0, power options don't work with this skin. Whenever I have to shutdown (restart and suspend don't work either), I need to change the skin or shutdown via SSH.
Any way to fix it?
(2021-07-31, 08:42)Letrix Wrote: [ -> ]For some reason, on LibreElec 10.0, power options don't work with this skin. Whenever I have to shutdown (restart and suspend don't work either), I need to change the skin or shutdown via SSH.
Any way to fix it?
Skin settings -> custumize home menu -> power -> choose action for shutdown, restart ...
I was a long time used of Horizon and Eminence. I wanted a change, still using Kodi 18.
I noticed that during playback the video OSD does not show the time remaining of a video. Usually there is a setting but I couldnt find such setting in Aura.
Can Aura actually show the remaining time of video playback?
(2021-08-15, 23:09)htcguy Wrote: [ -> ]I was a long time used of Horizon and Eminence. I wanted a change, still using Kodi 18.
I also have a question about AURA video OSD.
Mine is regarding Music Videos. When a Music Video is playing Aura shows the Music OSD rather than the usual Video OSD .
I would much rather see the nice minimalist Video OSD when a music video is playing.
Any simple xml edit that could achieve this?
Thanks so much if anybody can help
The Aura Mod for Matrix is one of the nicest Skins. Love it.
Thanks... had switched to Artic Reloaded, but Aura has been my absolute fave Kodi skin. Will switch back, but hope this mod keeps getting updated.
Got the Auro Mod installed but get frequently a pop up about Youtube acces not installed. Can I get rid of this? Trailers play fine.
