jurialmunkey,
Wow thanks .... I understand this is prob just an issue for me ??
Anyway any easy way of checking of that folder is one level up and then do the "MOVE" or if not just look where you were
Actually on the images one can i add a filter for fanart*.jpgs ? instead of a path ?
$INFO[ListItem.Path,,/../fanart*.jpgs
Awesome skin, thanks.
How do I remove watched movies from recently added movies widget.
Silki - Unfortunately not. Not really any way to check if a folder/file exists from inside the skinning engine. That's why I generally avoid local file stuff like this. Also, not possible to filter images afaik.
(2018-03-09, 19:48)Iceman360 Wrote: [ -> ]Awesome skin, thanks.
In the home customisation screen add the unwatched movies widget:
Default Widgets > Movies > Unwatched Movies
Then set sorting (AZ arrow icon) to "dateadded" (all one word, lowercase, without the quotes).
Then set direction to descending (the next arrow icon on the right)
The widget should now say:
UNWATCHED MOVIES | DATEADDED | DESCENDING
We change the sorting because the unwatched movies widget usually uses random sorting, so we override it with the sorting options to show in recently added order.
Jurialmunkey,
I have background transparency set to reduced, but would like to have dialogvideoinfo at increased. I've tried different combinations in include global with no success. Can you point me in the right direction?
thanks
jurialmunkey
I added the file again but the same thing happened, Downloaded the latest git, everything is ok now
jurialmunkey
I am attempting to bring the Video Info screen from Aura over to (fuse)neue.
Perhaps I have bitten off to much with this one. I am failing miserably so far.
Can you offer any tips and insights or is this destined to fail.
Thank you
(2018-03-10, 02:02)mxlance Wrote: [ -> ]@jurialmunkey
Thank you
I replied in your mod thread to keep this one clean.
(2018-03-10, 00:10)Edworld Wrote: [ -> ]Jurialmunkey,
thanks
Try this for global_fanartdim:
<variable name="Global_FanartDim">
<value condition="Skin.HasSetting(DisableVignette) + [Window.IsVisible(DialogVideoInfo.xml) | Window.IsVisible(DialogMusicInfo.xml) | Window.IsVisible(DialogAddonInfo.xml) | Window.IsVisible(script-script.extendedinfo-DialogVideoInfo.xml) | Window.IsVisible(script-script.extendedinfo-DialogInfo.xml)]">FanartDim_NoVignette_Increased</value>
<value condition="Skin.HasSetting(DisableVignette)">FanartDim_NoVignette_Reduced</value>
<value condition="[Window.IsVisible(DialogVideoInfo.xml) | Window.IsVisible(DialogMusicInfo.xml) | Window.IsVisible(DialogAddonInfo.xml) | Window.IsVisible(script-script.extendedinfo-DialogVideoInfo.xml) | Window.IsVisible(script-script.extendedinfo-DialogInfo.xml)]">FanartDim_Increased</value>
<value>FanartDim_Reduced</value>
</variable>
Quote:@MitchZombie -- Thanks. I've enabled all the viewtypes for AEL. I haven't used AEL in a long time and don't have it set up, so I have no idea which views actually work properly / are suitable.
Thanks a lot!
All the View types seem to display the games art correctly, Just missing the text for the games Media data (Title on some views , Date.Rating and Plot)
Would be great if you could have a look at it again.
Thanks Again!
MitchZombie
Can you tell me what views are missing what info so I can fix them?
Also is there another skin or view that does show the info so I can compare?
(2018-03-10, 04:20)Edworld Wrote: [ -> ] (2018-03-10, 03:58)MitchZombie Wrote: [ -> ]Quote:@MitchZombie -- Thanks. I've enabled all the viewtypes for AEL. I haven't used AEL in a long time and don't have it set up, so I have no idea which views actually work properly / are suitable.
Thanks a lot!
Thanks Again!
Can you post some pics?
MitchZombie -- Yeah, screenshots would help a lot.
