(2018-03-18, 00:44)Edworld Wrote: [ -> ]Jurialmunkey:
Maybe it is by design, but the viewed check mark on focused is green while the others are gray
On Krypton or Leia branch? I'm not seeing this?
How it should be (assuming default dark indicator style)
List view - all are monochrome
Poster views - unfocused watched is green, unfocused new is blue, all focused indicators are light gray.
Here's one more...music widgets with more than 3 lines show part of the 4th line.
braz - Should be fixed on latest git. Let me know if it's not. The laptop I'm working from has a 1366x768 resolution (so not perfect 16:9), which means it can sometimes do weird things to textbox alignment. Textboxes will look fine on my screen but can be a little off when I switch to a proper 1920x1080 display.
My PVR client allows season and episode numbers to be appended to the program name but your skin doesn’t seem display this info on the OSD pop up while watching live tv. It’s just showing the show title. The info is there as the “TV Channels” section shows this info.
Would it be possible to include this info on the info pop up while watching live tv?
Loving the skin btw. Thanks!
(2018-03-18, 05:12)Hardax Wrote: [ -> ]My PVR client allows season and episode numbers to be appended to the program name but your skin doesn’t seem display this info on the OSD pop up while watching live tv. It’s just showing the show title. The info is there as the “TV Channels” section shows this info.
Can you test latest git and see if they are working now. I don't have a working PVR setup currently, so I'm pretty much skinning blind in that regard.
Sir, here's a request. Could you kindly add the names for in this place for Studios so that users like me (who have deselected Wall Views Text Label option) can see which studio it is. Same goes for Addon window. Thank you.
Here's another thing. Not sure if its really an issue, but here goes..
Just while navigating from one setting to another in the Settings window, the fanart in the background fades out and fades in within a split-second. Could it be fixed?
Just to suggest. Wouldn't it be
minimal to display just the year of release instead of release date? The release date could be added in "Information" section of Dialog Info Window. Plus, why is the runtime showing like that? I liked it better before as
xyz mins.
VikkiXavier - I assume you are on Leia. There were recent changes to the skinning engine that changed the format of duration labels. I simply haven't got around to updating them yet, as the changes were only made a day or two ago. Should be fixed now on the Leia branch.
The fade in the background is because the settings windows are actually all separate windows and I use some clever hacks to make it appear as if they are all the one window. Please try latest git and see if it fixes it. If it doesn't then there isn't much I can do about it.
Not a fan of putting the label in the header. This is why there are labels on the wall views to start with.
Awesome looking skin, a quick quesiton.
Im having issues with ratings from rotten tomatoes / metacritic working.
IMDB is there, and after a second or to i get tmdb ratings. I back omdb on patreon and have the api key inserted in the metautils (under managed depencdies), tried restarting, deleting cache and all sort of stuff. But to no avail. Im on mobile right now, so i cant post any pictures or logs, but wanted to ask if this is common.
thanks again for your work
(2018-03-18, 00:55)jurialmunkey Wrote: [ -> ] (2018-03-18, 00:44)Edworld Wrote: [ -> ]Jurialmunkey:
My bad, I worded it wrong, using windows7 Krypton
(2018-03-18, 05:41)jurialmunkey Wrote: [ -> ] (2018-03-18, 05:12)Hardax Wrote: [ -> ]My PVR client allows season and episode numbers to be appended to the program name but your skin doesn’t seem display this info on the OSD pop up while watching live tv. It’s just showing the show title. The info is there as the “TV Channels” section shows this info.
Thanks - that works! A few observations.
Seems to have lost the episode name which was there before. It used to show “Fixer Upper - Waco Dreamhouse” - Now it shows “3x3 Fixer Upper”.
Season and episode on the OSD pop up is in the format “3x3”. On the TV Channels screen, it’s presented as “S03E03”. Just a consistency thing.
Yes, u r right I am on leia.
The thing is could you implement such that the text labels in wall views, if disabled, would apply only to Movies and TV Shows and nowhere else?? Would be really helpful.
PS: That hack you used in Settings window is just genius stuff. Now it doesnt blink no more. hank you. You deserve another golden ticket for your awesome work, Sir. Will donate once I return home from work.
