Full Version: Aura
There is double media flags in this view when we enable setting to replace rating with media flags.
And ratings are not aligned with mediaflags.
Any way to add moving Widgets up and down like the Main Menu items in the Customize Main Menu menu?
Hi.
I don't know if its a bug but on Kodi 18 alfa on android don't work skin backup option. On Windows works fine.
When I chose backup button noting happen. When I trying restore backup made on windows shows standard progress bar but settings don't restore.
Can someone check if its only in my case?
@jurialmunkey
when subtitles were already downloaded I use to get a nice simple enable/disable option, when I clicked on the subtitle icon
After clicking on the subtitle icon. latest git
(2018-04-19, 00:41)Blurayx Wrote: [ -> ]@jurialmunkey
I asked for this change, that dialog is new in Leia. IMO, this is better because it provides quick access to adjust subtitle offset, etc.
(2018-04-19, 00:51)braz Wrote: [ -> ]
Personally, I prefer the previous version, plus it auto closed after enable/disable. I hope jurialmunkey can add a minimalist option  Smile
I agree with braz on the subtitles issue
(2018-04-18, 04:47)jurialmunkey Wrote: [ -> ]@VikkiXavier - I've added the top250 position number for top250 widgets. Sorry about the wait! Ratings votes options are coming soon! Wink
Thank you.
@jurialmunkey
Can you please pm me the code, regarding #681  Smile
(2018-04-19, 00:41)Blurayx Wrote: [ -> ]Personally, I prefer the previous version, plus it auto closed after enable/disable. I hope jurialmunkey can add a minimalist option  Smile
Maybe it would be possible to add another icon that just toggles subtitles and only shows if they have been already downloaded.
(2018-04-19, 14:23)Nervosa Wrote: [ -> ]
If jurialmunkey can't add a minimalist option, Your idea would be an excellent compromise  Smile
(2018-04-06, 00:22)jurialmunkey Wrote: [ -> ]
(2018-04-05, 20:20)Zpower Wrote: [ -> ]Thanks for the good work. I´m an Fan.
Its possible add media flag on this view?
There's not really any room anywhere.
I'd love to have media flags as well for this view. Possible as an option for users in the ratings line? I'd prefer media flags (specs) over what reviewers/Oscars think Smile.
Thank you for this skin. Only Leia-compatible skin I really like... figures as I love your Artic skin, and look forward to its appearance for Leia.
My only request:
- Vertical Menus
+1 and may I add its a wonderful skin
(2018-04-20, 16:59)Zpower Wrote: [ -> ]My only request:
- Vertical Menus
I was never brave enough to ask for a vertical menu but uhm yeah..
+1! Smile
