Full Version: Aura
(2018-05-26, 18:21)sflix Wrote: [ -> ]
(2018-05-26, 08:46)jurialmunkey Wrote: [ -> ]
(2018-05-18, 20:51)sflix Wrote: [ -> ]@jurialmunkey
Not movies per se, its for my smart play lists. I don't like to look at carpet icons.  I'm just that big of a thick head.
I wanted a nice way to display the smart playlist, so I tried to make an addon.
I couldn't make the addon work properly with the smart playlist, so I just mounted an emby server, to display the lists.
That way I managed to put art on my smart playlists and use them as menus. I have all of the images of the collections, but they are 512x512.
Sorry for the delay getting back to you.
Does this mounted emby server have content type set to "sets"?
No worries. Yes it does.
Okay, well you can change which content types are excluded from the big square view by editing: Includes_View_Posters.xml
Big square view is id="503" so you will need to find the panel control with that id in that file and then change the visible condition which looks like this:
<visible>[!Container.Content(movies) + !Container.Content(tvshows) + !Container.Content(seasons) + !Container.Content(songs) + !Container.Content(videos) + !Container.Content(episodes) + !Container.Content(sets) + !Container.Content(actors) + !Container.Content(images)] | $EXP[Exp_IsPluginAdvancedLauncher]</visible>
From that line, you need to remove:
Smile I was on the right track on tinkering, but i didn't get any results when I modified the xml. Sure I missed something.
I'll try later again. Thanks a bunch anyway.
(2018-05-26, 08:37)jurialmunkey Wrote: [ -> ]@Blurayx - Alphabet strip should now be back on Leia. Setting is at Skin Settings > Miscellaneous.
Thank You  Smile Wink
btw please don't forget to add minimalist subtitle GUI option. Alternatively auto close when subtile has finished downloading(None minimalist sublitle GUI) if possible
Wow really?
But it does not show up for me.. Or works in any way.
Any ideas?
(2018-05-26, 21:30)Animizio Wrote: [ -> ]Wow really?
Any ideas?
Works perfectly fine for me. Maybe check that you actually have nextup enabled and that the service is running.
Otherwise, you will need to ask in its thread:
https://forum.kodi.tv/showthread.php?tid=228435
NextUp:
PostPlay:
(2018-05-26, 20:44)Blurayx Wrote: [ -> ]
Added. Minimalist option is enabled by default now (as full subs menu can be accessed in the osd settings cog menu).
Option to toggle behaviour in Skin Settings > Video OSD
(2018-05-27, 05:04)jurialmunkey Wrote: [ -> ]
 Excellent. For my personal use, Aura Leia is now complete  Cool
Thanks!!!!
@jurialmunkey All is working great now. Thank you.
Is it too early to request that Aura be the default skin in Kodi "Leia"?
Sir, I don't know if this is even possible or not, but let me ask. Can you to add a shortcut to change actor thumb directly from here?
a little request from me:
can you make show up the studio logo of tv shows or movies
like fade animation
(2018-04-22, 14:18)Anthony_Toni Wrote: [ -> ]Hi jurial, I am in love with your skin. Just moved over from Aeon MQ 7 to Aura. But there is one request I would like to make..
Could trailers and videos in extras be made to play in a small window with a background behind and a seek bar? - Loved this in MQ, which I miss in yours.
 its been quite a while. have you begun working on it yet? m just curious Smile
I'm afraid this skin didn't work out for me. I have found the skin.helper.service add-on causes Leia to freeze upon shutdown (Android Fire TV). I had to uninstall it.
I didn't actually manage to successfully install the skin either, though it did manage to install the above dependency.
(2018-02-17, 08:16)jurialmunkey Wrote: [ -> ]-
Hey Jurial, any chance of adding a font that can display asian characters? The Arial font only shows boxes as soon as it writes Japanes characters. Does the roboto font family support them you think? Arial-based is ugly, but I'll of course take it if it displays the writing. The default font in Aura doesn't draw them at all and the Arial leaves unknown boxes.
Thanks. Smile
There seems to be some kind of glitch just before the trailer plays when the fanart in the BG disappears for a second or so
(2018-05-27, 06:36)ZefXyde Wrote: [ -> ]@jurialmunkey All is working great now. Thank you.
Excellent. Glad it's working now.
Haha. I think most people are pretty happy with Estuary being the default. Plus, I enjoy the freedom of not having to worry about some of the things that the default skin needs to.
