Full Version: Aura
(2018-08-12, 05:10)Hardax Wrote: [ -> ]
(2018-07-31, 14:02)Hardax Wrote: [ -> ]
(2018-07-31, 10:56)jurialmunkey Wrote: [ -> ]Is this on Krypton or Leia? It is working properly for me on Krypton. Note that if you press a remote direction or move the mouse etc before the busy loader comes up, then the movie will unpause.
This is on Krypton. All I'm doing is bringing up the OSD and selecting the "i" inside the bubble. Video pauses as extended info loads then once its loaded video starts playing in the background. Ive not touched the remote during this procedure. I can try and get you some logs tonight if that would help?
Trying out the latest nightly of Leia @jurialmunkey and the same behavior exists. As soon as Extended Info finishes loading the video resumes in the background.
The pause on info seems to be a standard feature now and I’ve confirmed that it works correctly with other skins (Estuary Mod v2 & Emburary). Aura is the only skin that’s giving me problems.
Figured it out @jurialmunkey.
If you set a value for the skin setting:
Video/Music OSD
Auto close OSD controls...
It cause the behavior listed above if any numeric value is entered. If it’s blank then the pause works as expected.
@Hardax - Ah ok, I don't use that setting generally, so that's why I wasn't seeing the issue. Good detective work! I'll have a look tomorrow and see if I can figure out a fix.
@danjames92 - that is the most recent version. I've been busy with work the past month, so haven't had any time for skinning. Things are settling down a bit now, so might be some new updates in the coming fortnight.
(2018-08-25, 09:31)jurialmunkey Wrote: [ -> ]@danjames92 - that is the most recent version. I've been busy with work the past month, so haven't had any time for skinning. Things are settling down a bit now, so might be some new updates in the coming fortnight.
 would be awesome JurialMunkey
Hello. Is it possible to auto play movies & tvshows trailers? Or maybe can you make an option to make that possible? I mean in the widgets or/and in the different viewtypes.
It would be really nice ( in my opinion) when you highlite a movie or tvshow, you automaticaly get a trailer after a few seconds.
(2018-07-20, 11:49)jurialmunkey Wrote: [ -> ]
(2018-07-16, 02:01)Hardax Wrote: [ -> ]Could we get a little more info for the live tv area? Specifically the default “watched channels square view” in Embruary skin lists the channel logo and below it the show name and starting and ending time below. See attached. I find that very useful at a glance info.
Thanks as always!
I will have a look at what I can do once I get through a few of the other outstanding items on my skinning todo list.
@jurialmunkey if there is a chance you could look into this request from last month when you get back into things I’d be a happy camper! It really is the only thing that I keeps me 100% loving this skin!
Thanks for the reply @jurialmunkey. Are you aware of the freezing widgets in Leia then?
A lot of the time when playing back something picked from a widget, it'll crash the skin and then reload, 2nd time it works fine.
loving this skin. Real help in reminding me where I'm watching which shows thanks to custom list at trakt.
Hi all,
@jurialmunkey, is there a way to use thumbs on smartplaylists?
I've tried putting the playlist in a folder and then add a folder.jpg but it doesn't pickit up.
(2018-09-01, 14:35)sflix Wrote: [ -> ]Hi all,
Do you mean as a widget or in the library?
@jurialmunkey
Hi
I would love to see "Movies in this set" as an Info Dialog option. For example, if I open "Star Wars: A New Hope" Info page, scrolling down will show the cast, other movies by this director, and then at the bottom somewhere "Also In this Set: "Empire Strikes Back, Return of the Jedi". Knowing that a movie is part of a Set really helps when browsing the library.
Also, forced views would also be very nice, so we can set Lovefilm to be used for Sets, while still keeping Poster Wall for non-Sets.
(2018-09-03, 11:48)Eddie Strike Wrote: [ -> ]@jurialmunkey
Hi
Forced views are already possible. Click the lock icon in the top menu and it will lock that viewtype to the current content type.
Good idea about movies in set for info. I think it should be possible, so I will add it when I get the chance.
Hi.
This skin is my daily driver. love it. But i have a few questions.
I listen to music with the amazon prime music addon.
  • is there a way to see fanarts in the background like esturary mod v2? http://i.imgur.com/im3oQKL.jpg
  • dont dim the monitor when playing music
  • is there a way to always show the osd?
thank you
Just wondering, for the Guide, it does a nice job of showing the grid, but the only way to see program info if to click a couple times. Is there any way to get program info to show on the bottom (and scroll if long).  This is mainly for sports, such as NFL. In the grid, it just says "NFL Football" and need to look in description to get the teams. I would be nice to have that quickly.  Other sports are the same.
Thank you
Sir, when is the next update coming? 😯
