I've been away from Kodi for some time and forget how to fix stuff like this. Any ideas?
13:24:27.448 T:140697213884160 ERROR: Requested path http://mirrors.kodi.tv/addons/krypton/re...-0.0.6.zip not found in known repository directories
13:24:27.448 T:140697213884160 ERROR: CAddonInstallJob[resource.images.moviegenreicons.transparent]: failed to resolve addon install source path
13:24:27.449 T:140697213884160 ERROR: CAddonInstallJob[skin.aura]: failed to install dependency resource.images.moviegenreicons.transparent
Platform: Kodi
Operating System: LibreELEC 8.95.003
Device: Asus Chromebox CN60
Add-on affected: Aura skin
Version of Kodi: 18.0
Version of add-on: 0.9.36
Country: Australia
Any support services: Debrid (inactive)
Link to full debug log
Probably a dumb question but, Is there a repo I can use to keep this skin updated? Just got a notification that the version I have is not compatible with the latest version of Leia. I've been manually installing this skin by dropping the files into Kodi. Is there a better way to do this?
(2019-01-21, 08:15)SheHateMe Wrote: [ -> ]Probably a dumb question but, Is there a repo I can use to keep this skin updated? Just got a notification that the version I have is not compatible with the latest version of Leia. I've been manually installing this skin by dropping the files into Kodi. Is there a better way to do this?
No I don't do beta repos. I find them too much hassle to make sure they stay updated.
Manual install is the way to go.
However, now that I have game support finished and all the other Leia changes updated, I am planning to have the skin on the official Leia repo in the next fortnight.
(2019-01-21, 06:54)kain0rer Wrote: [ -> ]I've been away from Kodi for some time and forget how to fix stuff like this. Any ideas?
Platform: Kodi
Country: Australia
You could try manually installing that add-on from the zip. The link from the mirror works for me to download it.
(2019-01-20, 19:36)ontap Wrote: [ -> ]No issues using pvr on firestick.
Excellent. Thanks for confirming.
Did you try scrolling around from the top to the bottom - i.e. click up to the menu and then up again to get to the bottom (and vice versa)?
Yep did all that no problems.
(2019-01-21, 10:18)jurialmunkey Wrote: [ -> ] (2019-01-21, 08:15)SheHateMe Wrote: [ -> ]Probably a dumb question but, Is there a repo I can use to keep this skin updated? Just got a notification that the version I have is not compatible with the latest version of Leia. I've been manually installing this skin by dropping the files into Kodi. Is there a better way to do this?
Great news Aura will be an official Leia repo
Aura is the best skin ever!!!
I love Aura so much that I want to put it on my several devices. But I'm not sure how I go about transferring my configuration around. Could somebody comment the best way to do this?
Where are the aura skin settings stored that are important?
Go to aura skin settings /manage dependancies and install skin helper back up service and back up the skin. Then transfer back up folder to the new machine. Worked perfectly for me
Hey new user of your skin, loving it so far.
On my home page I have a lot of empty space below the show/movie listings
I was wondering if I could put maybe the descriptions of the highlighted TV/Movie thumbs or maybe a scrolling poster list? something that is changing that would be nice to have on tv when you aren't watching anything. Thanks
Hello, great skin, looks gorgeous but just one thing is missing for me: my personal ratings of movies from 1 to 10 that i used to see on the default skin. Is there a way to being that back ?
