(2019-01-24, 18:43)zamal Wrote: [ -> ]Hello, great skin, looks gorgeous but just one thing is missing for me: my personal ratings of movies from 1 to 10 that i used to see on the default skin. Is there a way to being that back ?
If you have a user rating set, it will show in the star rating in the info instead of using the imdb rating.
(2019-01-25, 07:56)Steveb Wrote: [ -> ] (2019-01-21, 10:15)jurialmunkey Wrote: [ -> ] (2019-01-20, 20:04)Blurayx Wrote: [ -> ]@jurialmunkey,
When you get time, can you please fix the overlapping text
https://forum.kodi.tv/showthread.php?tid...pid2807990
Actually, it looks like a Kodi core bug as the problem is present in Estuary also.
Bug report filed here: https://github.com/xbmc/xbmc/issues/15302
This can be fixed by adding <textwidth>….</textwidth> to the sliderex in DialogAddonSettings.xml.
Yeah I know. I filed the bug report which led to the workaround being implemented in core. Just haven't got around to adding it to the skin yet.
(2018-07-21, 03:08)jurialmunkey Wrote: [ -> ] (2018-07-20, 20:11)xbishop Wrote: [ -> ]I love this skin so much!
One of the features I'd like to see is that Aeon Nox displays the random fanart's title (show/movie) in the bottom left corner on the screen when you're on the home page. Any way of getting that added?
And maybe a vertical homescreen? My wife hates the boxes and told me to ask about vertical or if we could have that or if we could hide the boxes until we hit down.
Thanks! Glad you like it.
Not really a fan of how Aeon Nox shows the title like that. Plus, this skin is designed to show multiple widgets, so I think having text on screen like that will be confusing.
Vertical homescreen has been planned for quite a while, it's just a matter of me finding the time to actually finish it.
What do you mean by boxes? Are you talking about the categories widget?
You can disable the categories widget in "Skin Settings > Home > Categories widget".
To access the submenu with categories widget disabled, press up from the top menu.
jurialmunkey Is the vertical home menu still on your shortlist? Pretty much the only thing keeping me from switching over from AZ.
(2019-01-25, 11:02)iophobia Wrote: [ -> ]@jurialmunkey Is the vertical home menu still on your shortlist? Pretty much the only thing keeping me from switching over from AZ.
Yes definitely. Hopefully sooner rather than later if my ideas for it end up working out.
(2019-01-25, 13:19)jurialmunkey Wrote: [ -> ] (2019-01-25, 11:02)iophobia Wrote: [ -> ]@jurialmunkey Is the vertical home menu still on your shortlist? Pretty much the only thing keeping me from switching over from AZ.
That's very nice to hear. Great
Hi, i have searched this thread but havent found an answer, so forgive me if this has been asked before.
When i add multiple episodes of one TV show, every episode is shown in the "recently added episodes" widget.
Is it possible to group them, so when i have 9 new episodes from the same show, only one poster shows in the widget?
(2019-01-25, 14:26)cirkator Wrote: [ -> ]Hi, i have searched this thread but havent found an answer, so forgive me if this has been asked before.
I'm not sure if this is possible. Do you know of any other skins that do this?
you can do this with a smart play list, then use a a widget
I'm using Libereelec and updated to the latest Beta .03 now the Dependency is not valid anymore and I can't enable this Skin anymore. What can I do?
(2019-01-26, 14:36)cd492 Wrote: [ -> ]I'm using Libereelec and updated to the latest Beta .03 now the Dependency is not valid anymore and I can't enable this Skin anymore. What can I do?
Download the latest version of the skin from the Leia branch and install.
https://github.com/jurialmunkey/skin.aur...e/Leia.zip
Be sure to give the zip file a unique name, otherwise Kodi will use a cached version.
That works for me with the widget "Recently Added TV Shows"
