Probably a quick fix everybody but still new to all this. Trying to sort my collection widget that links to **banned addon removed** (edit: jurialmunkey) by alphabetical order. What do I need to type in the AZ section for it to sort. Tried a few things and no luck yet.
TIA
Hello,
I'm not sure if I was understandable here.
Basically, when I go to "TV series in progress", I have the vignette of my episode.
If I click on it, it brings me back to the card of the series, and I have a read button in the top left corner.
If I click on it, instead of reading me the episode I should see, it opens up the tree structure of the whole series, with the seasons and so on, and I have to navigate to reach the episode. As on the basic Kodi without skin.
How do I get it to read the episode directly ?
Thank you.
Hello @
jurialmunkey
Image for codec not showing.
Can you say why?
Long time Titan user which made the upgrade to 18 and decided to try something new and found this fantastic skin, thank you jurialmunkey!
I did have one question. I have everything dialed in but TV Shows. The default is List view which I am trying to change to Media Info. At the root of TV Shows I set it to Media Info and it works but does not recursively set it for all shows and seasons. I even tried locking the view but that did not work either. Is there a way to to set the view and have it applied to everything?
Thanks again for this amazing skin!
Hi, I'm having trouble understanding how exactly I'm supposed to configure AEL in this skin. I've added AEL as a homescreen item, with widgets set to each game, leaving me with something useable, but I feel like this isn't exactly how I'm meant to be doing it. It seems vary laborious, and there isn't anywhere to view any of the metadata that seems to be part of AEL, so I was wondering if I'm actually doing it correctly. What exactly is the process for adding AEL to Aura?
Hi @
jurialmunkey
Thanks for this great skin. I'm a long time user of fuse neue, but after having my shield upgraded to Leia (without my approval lol) and having some annoyance with fuse, i've decided to look for something else.
Waiting for AZ2, I've found this great and beautiful skin!
I'm asking if one thing is possible though : in the widgets, would it be possible to group films in sets, like in library views?
Would it be possible to create a skin shortcut leading directly to the screen "customize home menu"?
(2019-02-07, 15:54)Zpower Wrote: [ -> ]Hello @jurialmunkey
Can you say why?
Means that there isn't a codec image for whatever that codec is (or kodi is not recognising the codec). Do you know what codec the film is encoded as?
Amazing Skin!
Problem im running into is pvr_art_stripchars from metadatautils not seeming to work. Does this work for other people?
Hi, I have one questions is there a "system info" widget to get live info about the system from the home screen?
Pleased to announce that Aura is now available on the Official Leia repo!
Big thanks to everyone that has helped with testing, provided suggestions, or submitted bug reports! Keep it up!
