Full Version: Install the Kodi Android Installer for Kodi Krypton
With this add-on, you can download the zip file manually from the Kodi page.Install the Kodi Android Installer for Kodi Krypton (v17.x)
  • From the home screen at the top, select the icon of the open box.
  • Now choose Install from zip file and click on the file you just saved labeled script.kodi.android.update-x.x.x.zip.
  • Wait for the enabled message.
  • To access, go to Add-ons > Program Add-ons > Kodi Android Installer
My question is, where do I find the file "script.kodi..."etc?
Thanks...............Upson........................later...
Where did you get those instructions from?
The upgrader is available in the built in official repo - install it from there and then you'll find it under program addons.
Just go to the add-on browser, select install from repo, choose the official repo and then the program addons section.
For reference, the support thread for that addon is here .
Thank you Darren, exactly as you stated. I followed your instructions and voila it's done!
you're the best..................Upson................................later...
Thread marked solved.
