Full Version: Issue scraping new albums when Fetch Additional Information is on
Pages: 1 2
Dave,
there seems to be some sort of issue scraping new albums
when Prefer Online Information is off and Fetch Additional Information during Updates is on
I am running this V18 nightly KodiSetup-20180220-f6030103-master-x64.exe on windows 10 64bit
When a new album is found it seems to get added to the database ok, but then sticks at the scraping window in top right hand corner of confluence screen
if you then select stop scanning the album shows up in recently added albums
I have a debug log at https://pastebin.com/raw/JPJcge5F [please note I had to remove a large amount of of DoScan Skipping dir lines to get below pastbin 512mb limit]
The Album I added was The Blue Zone by Nic Potter the tracks are in flac format
if Fetch additional info is turned off no issues appear
The Artist exists in MusicBrainz but this specific album does not appear too
Let me know what other debug info you require
(2018-02-21, 14:02)tkgafs Wrote: [ -> ]The Album I added was The Blue Zone by Nic Potter the tracks are in flac format
 I have just tried adding another album in this case The Smiths - Hatful of Hollow
specifically because in this case both the artist and the album exist in MusicBrainz
and the there was no issue scraping the album
so issue seems to occur when either the artist or the album does not exist in musicbrainz
(2018-02-21, 14:32)tkgafs Wrote: [ -> ]
 forgot to add the debug log for the good scrape its here https://pastebin.com/raw/NA1cRKTM
Thanks Tim. Looks like it is just repeatedly trying to scrape the album that isn't in Musicbrainz, until you stopped it.  I'll dig into it, I have not had that before.
Tell me was this the only new album when you did the library update, or were there others?
(2018-02-21, 15:27)DaveBlake Wrote: [ -> ]Thanks Tim. Looks like it is just repeatedly trying to scrape the album that isn't in Musicbrainz, until you stopped it.  I'll dig into it, I have not had that before.
 No it was the only album, I noticed the issue a couple of a days ago so specifically set out to try and see what problem was
I think I may have seen something like this on an install I have on my HTPC that I am sort of "beta testing" my skin mod.  I did an UpdateLibrary(music) with settings prefer online OFF and fetch addl info ON.  During the scrape step it seemed to be caught in a loop.  Because it's on my HTPC it isn't as easy to trouble shoot exactly what is going on.  I will play around some on my dev system.
scott s.
(2018-02-21, 16:07)tkgafs Wrote: [ -> ]
Dave, any update on this issue ?
Not yet, I have been busy on other stuff. Also thunder took out by internet hub, and the replacement is stuck in the post because of snow - it has been an eventfull week! But I have not forgotten this, and will get to it soon.
no problem take your time
Finally looking at this, so bump to top of forum posts so I can find it.
EDIT: Yeap, I can reproduce. There's a flaw in the scanning/scraping processing loop
Pull request raised with fix PR13752. Thanks for reporting this @tkgafs
While there I have also improved the title of the progress bar to better track what Kodi is actually doing, I noticed it sometimes said it was scraping artists etc. when actually it was just checking files. So when it is just checking, not actually scanning tags or scraping, it now says so.
great, will the fix appear in tonights nightly ?
It’s not yet merged so won’t be in nightlies yet.
(2018-04-08, 14:38)tkgafs Wrote: [ -> ]great, will the fix appear in tonights nightly ?
No, that only happens once PR is reviewd, approved and merged. But I can get a test build brewing if you are willing to test it, win64 do you Tim?
yes win64 is perfect
Pages: 1 2
