I have a Zotac with an Intel Atom CPU D525 with an Intel Graphics Media Accelerator 3150. The menus will display but it isn't able to display any video DVDs, or a .mp4 file. I put Kodi 17.6 on the computer but it won't work. I even have a HDMI output.
Is it a lost cause?
(2018-02-24, 04:36)Thundarl Wrote: [ -> ]Is it a lost cause?
How can we possibly know. You haven't provided any information, logs, screenshots or a detailed explanation of what the problem is.
All I can offer you is this link to set up your library...
https://kodi.wiki/view/HOW-TO:Create_Video_Library
Tip 1:
Look what happens if you hit "\" or "ALT+Enter". It toggles between "Windowed" and "Full Screen".
Tip 2:
Try to check/change the followings in Settings>System>Display:
-Display mode
-Resolution
-Use Fullscreen window
-Use limited color range
lost cause:
Quote:Atom CPU D525 with an Intel Graphics Media Accelerator 3150
Neither hw acceleration nor proper 3D graphics acceleration
When I try to get watch a video add-on like 'Food Network', a DVD movie or a video in .MP4 format. I only get the Audio and if close-captioning is on then I also get close-captioning. The following is my debug logfile. I'm sorry but I don't know what is relating to the video problem. I tried to see if I could change the color setting but couldn't find that reference.
log removed, see below
Please do not post logs to the forum, use a PasteBin site.
As a courtesy for a first time I've moved it to PasteBin.Com but your log also doesn't have debug logging enabled so it's usefulness is reduced.
https://pastebin.com/S7CjYA8b
I screwed up and probably put too much in. Here's a link to a share folder in my Dropbox. It should be reachable but not sure.
i did put it into pastebin.com but could get a reference to post. I'll ask first next time I get a problem.
(2018-02-24, 21:07)fritsch Wrote: [ -> ]lost cause:
did you read ^^
I guess your last resort might be to turn of DXVA
Tried turning DXVA both and trying and turning DXVA off[font] and [/font] then trying it. No luck either way.
