Hi Gade,
Great to see you still working on this powerfull skin. I have a a question do.
When im going to the movie information in getting this thumbnail:
Same as here:
But when im going to extended information i do see the correct thumbnail. This is not for all movies just a few, any idea how i can fix this?
Which version of Rapier and which version of Kodi?
rapier 10.5.12
kodi 17.6 git:20171114-A9A7A20
That's most likely not a skin issue.
Proper naming of the file is very important. If the scraper can't find useful thumbs or posters, Kodi will use a screen grab.
I use Universal Movie Scraper, which I find the most powerful.
Try refreshing info to see if a poster will show up.
Movie information window > Manage > Refresh
Or you can go to the movie information window > Manage > Choose Art > Poster to see if you can choose another poster.
the naming is correct cause when i refresh its show me the correct movie title and year, also extended information gives me the correct picture. Altough i cannot change it with select art cause the image is not showing up in there. Might be a kodi issue indeed
Which info and images ExtendedInfo finds and shows has nothing to do with the images scraped by Kodi.
Check your scraper settings. Which scraper do you use?
What does it look like in Estuary?
Maybe you need to add the poster image manually if the scraper can't find one.
