Full Version: Next and Previous Episode button. & 4K UHD CASE CHANGE
Hello Everyone,
First of all Thanks everyone who contributed to make this skin , this skin is awesome awesome.. bin using it since day 1(KODI v15) I started using KODI and never used any other skin ever..
OK recently on V16.4 I noticed when i'm watching the tv show and I want to go to next episode and when I click on the middle button on remote and select next episode or previous episode it never works..
all my stuff is on SMB window shares.
I don't remember if it was working ever or not... I never used that feature ... but I recently updated to v18 nightly build so I can use voice commands..
all the voice commands works (play , pause and play specific movie ) but when I say play next episode or play next it says OK but don't do anything ...since physically pressing the button doesn't do anything either.
EDIT: first time I tried updating the v18 on top on v17.6 like KODI recommends.
since it never works I uninstalled everything and reinstalled KODI v18 alone and then did the whole library from scratch  ........ nothing from backup ...
Problem was there both times.
Can someone Please shed some light how can I fix this .
and My second question is .. recently I got a 4K UHD movie and KODI displays the box-art exactly like the Blu-ray with a litte tiny 4KUHD LOGO on it ... I want to replace it with the GOLD OR BLACK AND GOLD Logo... I can get the necessary skin picture by myself all I want to know how and where I'm changing  it ?
Location  of the skin ?
Do I need to update any kind of code ?
Also  right now I'm using Kodi v18 nightly build and using it on NVidia Shield 2017 16GB.
Movies and TV is stored on windows 10 PC and connected using SMB
I'll lay out the gorund work a bit first, to use Kodi V18 with T! you would need the Kodi for nightly builds and T! from git as note here. https://forum.kodi.tv/showthread.php?tid=195065 The SVN version would allow manipulation of glifs and images.
1) The next video function would work if you had a queue of vidoes/movies all set, then these function work. Ensure you have 'play next video autmatically' toggled in settings (exper mode) and you shouldn't even have to go next.
Investigate an add-on called 'Nextup Service Notification' hopefully this will work well  with your Android system. Back-ups into an new Alpha installation might involve re-scrape and building a new library at this point. This maybe resolved as we get closer to release.
https://kodi.tv/addon/services/nextup-se...tification
and support https://forum.kodi.tv/showthread.php?tid=228435
2) Replacing the 4K icon might be a bit problematic, it's kept in archived format in the textures. If you use the SVN version of T! from git, the image would be located in a PC C:\Usersyour_User_name\AppData\Roaming/Kodi/addons\skin.transparency\media and would be a simplier fix. For Android Shield Computer\SHIELD Android TV\Name_USB drive\Android\data\org.xbmc.kodi\files\.kodi\addons/skin.transparency/media perhaps placing the image here would allow T! to pick it up.
https://kodi.wiki/view/TexturePacker
https://kodi.wiki/view/TextureTool
