Full Version: Movies filters doesnt work
Hello.
I just installed skin on my libreelec and windows system and have the same issue:
Movies filter doesnt work. I mean filter by year, artist, collection and etc...
If i press on button then i get filter options but when i just press 'down' key few times on keyboard or remote control then kodi is hang and only random combinations of button resume kodi work.
SCreenshots
@jurialmunkey Could you please look into this issue?
I dont like other skins so i have no choice Smile
To me by looking at your screen shots is:
First is a widget, so its visible directly standing on the submenu
The second one you have to press OK/Enter to open it
(2018-02-25, 23:36)T-bird_se Wrote: [ -> ]The second one you have to press OK/Enter to open it
Yes. but the problem is if i dont press OK/Enter button and just press on down button then kodi become unusable. I dont know how to describe better. I'll try to record video.
Also, as you can see, kodi still display number of movies and scrollbar and meta information.
Install the beta version of skin shortcuts from github to get submenu widgets working correctly
https://github.com/BigNoid/script.skinshortcuts
(2018-03-03, 07:50)jurialmunkey Wrote: [ -> ]Install the beta version of skin shortcuts from github to get submenu widgets working correctly
 Thanks a lot. It works now.
