2018-02-25, 03:30
Hello,
i'm attaching a log which i captured few hours ago:
Kodi Log
I'm running Kodi 17.6 on Ubuntu 16.04, which is running on a HP G8 server with 16gigs of ram and a 2 core Xeon processor. I have added a Nvidia GT630 64 bit video card. My HDMI signal goes from the video card to my receiver and than to the TV. I've also attached a Pulse8 HDMI CEC dongle. I have set Kodi to run as soon as the server starts and it goes directly to it without going through any other user environment. This is my basic setup, i believe more information could be found in the log.
My problem is with "4K" MP4 files "produced" by a Panasonic G7 camera. They are with 3840 x 2160 which obviously exceeds my FHD output but i don't think this might be an issue. As soon as i start such video it start stuttering. It stutters so bad that it's unwatchable. Sound on the other hand is ok, the issue is only with the picture. I searched for similar threads, based on what i found i played with my hardware decoding options (VDPAU and VAAPI), i tried switching between them or completely turning them off. I also tried playing with the cache through the advancedsettings.xml file, but i cannot say anything made the video play better or worse. the clips i'm trying to view are running fine on other devices so i'm sure the issue is not with the files. i'm also sure that Kodi can read them fast enough since i've put them in one of the server's HDDs, so there's no LAN streaming and no USB bottleneck.
i also noticed that sometimes there's a slight stuttering when i'm watching particular 1080p TV rips which are about 4 GBs per 44 minutes and are in .ts format. everything else is running just fine. on the other hand i'm able to watch a 25gb 1080p bdrip movie in .mkv format without any stuttering. what could be the issue? bad codec? of weak hardware (the 64 bit video card)?
Kodi Log
