2020-03-28, 13:25
2020-03-28, 13:32
(2020-03-28, 13:25)thedeadman Wrote: [ -> ]Sorry mate, no clue on catchup. Most addons have details of their author and supporting materials in their 'addon.xml' file.
i think it has to be somewhere on pvrguide i am talking for live tv that supports catchup, also it has to be easy to edit but dont find where to read about it.
its on DialogPVRInfo.xml, added
Quote: <item id="5">but its not working
<description>Play Record</description>
<visible>Window.IsActive(PVRGuideInfo) | Window.IsActive(PVRRecordingInfo)</visible>
<label>19687</label>
<label2></label2>
<onclick>sendclick(pvrrecordinginfo,8)</onclick>
</item>
2020-03-29, 16:31
@fihc try this...
<onclick condition="Window.IsActive(PVRRecordingInfo)">sendclick(pvrrecordinginfo,8)</onclick>
<onclick condition="Window.IsActive(PVRGuideInfo)">sendclick(pvrguideinfo,8)</onclick>
2020-03-29, 16:53
(2020-03-29, 16:31)nonJon Wrote: [ -> ]@fihc try this...thanks, it didnt worked maybe it need to be edited more xml files
BTW i have managed to make it work with new button, sorry i used thread for kodi leia
added new button theres some bug with button id = 8
Quote:<control type="button" id="10">after that my item id
<description>Switch to Archive</description>
<label>Play Archive</label>
<include>Window.IsActive(PVRGuideInfo)</include>
</control>
Quote:all this change is on DialogPVRInfo.xmlxml:<item id="6">
<visible>window.isactive(tvchannels) | window.isactive(radiochannels) | window.isactive(tvguide)</visible>
<label2></label2>
<thumb></thumb>
<onclick>SendClick(pvrguideinfo,10)</onclick>
</item>
but the problem is title it show live title not title from guide
2020-04-07, 08:22
thedeadman
2017-03-16, 17:36
I'm not sure of your setup or experience with Kodi's innards, but you'll need to find where skin.pellucid is located on your system. On a Mac, it's ~/Library/Application Support/Kodi/Addons.
Anyway, once you're there, you need to replace the file skin.pellucid/1080i/custom_recentContent.xml with this one:
https://www.dropbox.com/s/owch1w5wrxbvml...t.xml?dl=0
________________
Hi and good morrning!
Please make a reup from this side?
https://forum.kodi.tv/archive/index.php?...279-6.html
THX for your hep!!
2017-03-16, 17:36
________________
THX for your hep!!
2020-04-07, 18:01
Hi, how can i enable watched and unwatched flags on View_AddonPosters.xml? It seems like there is no flags for watched or unwatched appear on the poster wall.
2020-04-08, 00:05
michelindeluxxe: Sorry - I no longer have that file to offer.
Napsters: Thanks for reporting. Fixed for next update, or download now from Github (see OP for link).
NOTE: Latest GIT commits includes experimental touchscreen support that is currently on by default. You can turn off the extra UI stuff by switching off mouse/touchscreen support in KODI settings.
2020-04-08, 11:51
(2020-04-08, 00:05)thedeadman Wrote: [ -> ]michelindeluxxe: Sorry - I no longer have that file to offer.
Hi! Do you have a code or hack please, for all open the menus or a backround pictures or liive Video? Thats a New idea. THX for help!!
2020-04-08, 17:35
Sorry friend, I don't understand what you are asking.
2020-04-09, 06:47
(2020-04-08, 17:35)thedeadman Wrote: [ -> ]Hi! My en is not perfect, so sorry👍😜
How can I install a background in the open menu? Which XML file must you take please a solution? Thank you
2020-04-09, 06:53
2020-04-09, 06:58
(2020-04-09, 06:47)michelindeluxxe Wrote: [ -> ]https://www.imagebanana.com/s/1721/noDkAqrv.html(2020-04-08, 17:35)thedeadman Wrote: [ -> ]Hi! My en is not perfect, so sorry👍😜
Sorry friend, I don't understand what you are asking.https://www.imagebanana.com/s/1721/noDkAqrv.html
2020-04-09, 07:50
(2020-04-09, 06:47)michelindeluxxe Wrote: [ -> ](2020-04-08, 17:35)thedeadman Wrote: [ -> ]Hi! My en is not perfect, so sorry👍😜
2020-04-09, 07:53
(2020-04-09, 06:47)michelindeluxxe Wrote: [ -> ]https://www.bilder-upload.eu/bild-1f24f5...5.png.html(2020-04-08, 17:35)thedeadman Wrote: [ -> ]Hi! My en is not perfect, so sorry👍😜
2020-04-09, 07:57
(2020-04-09, 06:53)michelindeluxxe Wrote: [ -> ](2020-04-09, 06:47)michelindeluxxe Wrote: [ -> ](2020-04-08, 17:35)thedeadman Wrote: [ -> ]Hi! My en is not perfect, so sorry👍😜
