2018-03-01, 21:49
In my shutdown menu I'm trying to display an icon that changes depending on which item is selected (e.g. exit, shutdown, sleep, etc), however I can't get it to work.
I've defined the icon whilst defining each item in the list, e.g...
As well as this I want the list to move depending on the number of items (so it is always central), for which I've tried...
Is there something I'm missing? This kind of thing works in other windows and I thought it would be simple enough here.
Thanks in advance.
Quote:<item>...and then tried to call it using...
<label>$LOCALIZE[13016]</label>
<icon>defaultactor.png</icon>
<onclick>Powerdown()</onclick>
<visible>System.CanPowerDown</visible>
</item>
Quote:<control type="image">but this doesn't work?! I've also tried $INFO[ListItem(9000).Icon].
<right>800</right>
<centertop>50%</centertop>
<width>380</width>
<height>380</height>
<aspectratio aligny="center">keep</aspectratio>
<fadetime>250</fadetime>
<texture colordiffuse="FF4A4F51">$INFO[ListItem.Icon]</texture>
</control>
Quote:<animation effect="slide" start="0,0" end="0,120" time="0" condition="Integer.IsEqual(Container.NumItems,7)">Conditional</animation>..again this doesn't work.
Thanks in advance.
