Full Version: Fire TV - Sound Channel Problem
Hey,
I have a recent problem with Kodi on my 1. Gen Fire TV:
On some videos the Downmix to stero doesn't work. I have some file sthat i extracted from the Blueray (don't have any BlueRayPlayer) so I can watch them via Kodi.
I did this with nearly all my DVD/BlueRays, there was never bevore such a Problem.
The rear-channels are mute. I don't get why. The Files work flawless on my Computer in MPC-HC/VLC.
Here the MediaInof from one of the videos:
https://paste.ubuntu.com/p/nFb7gZYD6M/
Any Ideas?
I have a 2.1 Audio System form Edifer wich is connectet via optical.
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
