Upgraded one of my boxes to Leia alpha, I did some fixes to this skin so I could have Sio2x on it.
Main 2 issues are the Home Menu customizer is broken and you can no longer change to custom backgrounds. <---Ok now
Toggle button broken on media shelf in home menu. <--- Fixed now for Movies, Tv shows, Music and addons.
also
1) added visually impaired (BIG) font option in Interface settings.
2) fixed some Live Tv, Epg and PVR bugs.
Everything works pretty well now, thought I would share.
Updated a lot more fixes and carried over to Matrix too.
skin.sio2x_leia
skin.sio2x_matrix
Also skinned the settings addon for LibreElec:-
service.libreelec.settings_leia
service.libreelec.settings_matrix
this fix works for me to install but still this install is not using the dependencies, so the design doesnt look at all like apple TV:
resource.images.tvOS-X-leia v1.0.0
resource.uisounds.tvos v1.0.0
script.skinshortcuts v1.0.17
how can i fix this? i am using Leia, i need it because of netflix and amazon video apps.
the normal installation doesnt work for me, only this fixed .zip works.
(2020-08-23, 14:39)RajeeRah Wrote: [ -> ]Hi,
i used this link and it works fine now.
https://github.com/fastcolors/skin.sio2
(2018-03-04, 14:08)celadoor Wrote: [ -> ]Upgraded one of my boxes to Leia alpha, I did some fixes to this skin so I could have Sio2x on it.
also
http://celadoor.github.io/skin.sio2x-leia-fixed.zip
Thanks for the update, great skin. In this version the TV shelf doesn't include the next up sort option (only recently added and random sorting). Is this something I did wrong in install or is it just not working? Its such a handy thing.
(2020-09-20, 05:01)webvixen Wrote: [ -> ] (2018-03-04, 14:08)celadoor Wrote: [ -> ]
Thanks for the update, great skin. In this version the TV shelf doesn't include the next up sort option (only recently added and random sorting). Is this something I did wrong in install or is it just not working? Its such a handy thing.Fixes
Now fixed this issue and a ton of others too, just get the update in the first post, these fixes have also been carried over to a Matrix version of SIO2-X, you can download that too from the first post.
