2018-08-03, 10:54
2018-08-03, 10:57
(2018-08-03, 10:54)jjd-uk Wrote: [ -> ]What SMB protocol version are you using? from what I understand SMB via the addon only works with SMB2/3 and won't work with SMB1.I'm using SMB support (libsmb2) enabled
2018-08-03, 11:14
What version of SMB is your NAS using is what I meant.
2018-08-03, 11:15
The question was, does your server support the SMB2 or SMB3 protocol and is it enabled?
2018-08-03, 11:30
(2018-08-03, 11:15)Rechi Wrote: [ -> ]The question was, does your server support the SMB2 or SMB3 protocol and is it enabled?Supports
SMB 1
SMB 2
SMB 2 and large mtu
SMB 3
2018-08-03, 11:37
I just enable SMB 3, restarted both xbox and nas, still no luck
Still get "Couldn't connect to network server"
2018-08-03, 11:53
Try using the IP address of the NAS in case the host name resolution is not working for you.
2018-08-03, 12:26
(2018-08-03, 11:53)jjd-uk Wrote: [ -> ]Try using the IP address of the NAS in case the host name resolution is not working for you.That was it. IP instead of hostname. Also the SMB info
Thanks for everyone's help, much appreciated
2018-08-03, 12:52
(2018-08-03, 12:26)stilcor Wrote: [ -> ](2018-08-03, 11:53)jjd-uk Wrote: [ -> ]Try using the IP address of the NAS in case the host name resolution is not working for you.That was it. IP instead of hostname. Also the SMB info
I would expect using hostname should still work, but I've not had opportunity to play much with SMB via the addon, at least you now have something working.
2018-08-04, 03:15
Hi All
Just want to confirm others experience here. I was able to get SMB support working on the XBOX One but only by specifying the IP address of the host(s). I Have two NAS devices connected, a Synology and a QNAP. Both a little older. One had the option to enable SMB2 in settings the other I had to enable it via a shell command. In any case I tried many time using hostname and it worked first time with both NAS's when I used IP address.
Also this is using a Shared MySQL Database on the QNAP with other Kodi devices throughout the home and it is working very nicely.
Great job team
Cheers
Great job team
Cheers
2018-08-07, 04:31
Still unable to download a version of Kodi that supports SMB.
2018-08-07, 08:45
What version do you have?
You can see it in the log or in Settings > System information.
2018-08-07, 17:51
(2018-08-07, 04:31)DGenerateKane Wrote: [ -> ]Still unable to download a version of Kodi that supports SMB.Same, and nobody is responding to requests to get added to the xbox test group
2018-08-07, 17:55
OMG, I FINALLY FOUND IT. No thanks to anyone responding.
Go to addons, all addons, scroll down to SMB support, enable. Seriously, this should be enabled by default, and stickied posts should be updated.
2018-08-07, 18:40
Did you not read first post? but yes the FAQ sticky is in need of an update.
