2018-03-04, 16:53
2018-03-04, 16:53
2018-03-04, 19:13
can you share a short sample to reproduce the issue?
2018-03-04, 23:16
(2018-03-04, 19:13)FernetMenta Wrote: [ -> ]can you share a short sample to reproduce the issue?Sure, two samples here :
https://drive.google.com/file/d/1VWZ343Z...sp=sharing
https://drive.google.com/file/d/1pGapO-T...sp=sharing
For info, I have the same issue with LibreELEC builds, issue starting with this changes (if it helps) : https://forum.kodi.tv/showthread.php?tid...pid2702465
You can see my posts here : https://forum.kodi.tv/showthread.php?tid...pid2709200
and here : https://forum.kodi.tv/showthread.php?tid...pid2709216
2018-03-05, 09:32
The root cause seems to be incorrectly encoded content. Your samples have HDR metadata MaxCLL set to zero. I doubt that this is valid but I can work around by ignoring values of zero.
2018-03-05, 12:56
(2018-03-05, 09:32)FernetMenta Wrote: [ -> ]The root cause seems to be incorrectly encoded content. Your samples have HDR metadata MaxCLL set to zero. I doubt that this is valid but I can work around by ignoring values of rero.They are full RIP of bluray 4K without encoding video. Maybe samples have this info. How do you find this info for checking my files (in mediainfo I don't find it) ?
This files was working before.
2018-03-05, 15:08
(2018-03-05, 12:56)Guilouz Wrote: [ -> ]Before there was no tone mapping, hence before colors were wrong.(2018-03-05, 09:32)FernetMenta Wrote: [ -> ]The root cause seems to be incorrectly encoded content. Your samples have HDR metadata MaxCLL set to zero. I doubt that this is valid but I can work around by ignoring values of rero.They are full RIP of bluray 4K without encoding video. Maybe samples have this info. How do you find this info for checking my files (in mediainfo I don't find it) ?
Now MaxCLL from HDR metadata is used if available. I checked this by inspecting field while doing source code debugging. Not sure if this info is exposed by some tool.
2018-03-05, 20:46
(2018-03-05, 15:08)FernetMenta Wrote: [ -> ]So, what can we do ? Because this files was working with others builds.(2018-03-05, 12:56)Guilouz Wrote: [ -> ]Before there was no tone mapping, hence before colors were wrong.(2018-03-05, 09:32)FernetMenta Wrote: [ -> ]The root cause seems to be incorrectly encoded content. Your samples have HDR metadata MaxCLL set to zero. I doubt that this is valid but I can work around by ignoring values of rero.They are full RIP of bluray 4K without encoding video. Maybe samples have this info. How do you find this info for checking my files (in mediainfo I don't find it) ?
2018-03-05, 22:49
I said that I can work around the issue. Problem solved already in master.
