2018-03-05, 03:49
2018-03-05, 22:25
I think you are not alone on that issue.
Did go over to run it on xbox native instead of in kodi.
Hopefully it will get solved in some further release.
Works if i run it on v17 on a rbp.
2018-03-05, 23:40
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
2.Restart Kodi
