Full Version: Hardware decoding
I understood that currently Kodi on Xbox one not supporting hardware decoding and that's why 4k are lagging. Correct?
Is this something that can be fixed by you guys or it's something waiting for Microsoft?
I know you are working hard and it's very appreciated, just want to know what to expect from 4k in Xbox Kodi and is it going to be fixed in near future.
Many thanks.
(2018-03-05, 10:30)yanivk Wrote: [ -> ]I understood that currently Kodi on Xbox one not supporting hardware decoding and that's why 4k are lagging. Correct?
No. Hardware decoding works great on XB1 except UHD hevc main10.
(2018-03-05, 10:30)yanivk Wrote: [ -> ]Is this something that can be fixed by you guys or it's something waiting for Microsoft?
Microsoft's guys trying to get a reason of this failure.
Ok, thanks!
So x264 8bit UHD movie should work fine? Because I have docu movie with these parameters that lag.
I am far from being an expert regarding all the video technical terms(such as x265,x264,etc) so sorry in advance.
Do I need to turn on the hw decoding manually?
Please advise.
BTW, x265 10bit UHD if far more lagging.
(2018-03-05, 19:42)yanivk Wrote: [ -> ]So x264 8bit UHD movie should work fine?
unfortunately but xb1 can't hardware decode uhd x264 files. It just has no h264 decoder for something more than FHD.
UDH hevc (x265) 8bit works well.
Ok I will try, thanks
(2018-03-05, 20:04)afedchin Wrote: [ -> ]UDH hevc (x265) 8bit works well.
 This applies to all xboxes? Even old fatty? Because all x265-files I have tried on mine have played slow and sound out of sync.
(2018-03-06, 10:08)bo1e Wrote: [ -> ]all x265-files I have tried on mine have played slow
What is bitrate of your files?
I tried 1080p, 3273 kb/s, Main [email protected]@Main and it's working since 25th February build.
CPU usage: 10-20%.
This is the info from one of the files that has given me trouble (from mediainfo):
Video
HEVC [email protected]@Main
Bit rate 2 149 kb/s
Width 1 920 pixels
Height 808 pixels
Audio
HE-AAC 199 kb/s
6 ch
