Full Version: Updated Unbehagen's ZDF-Mediathek for use with XBMC for Linux
Hello all,
i am running XBMC on Hardy Heron and wanted to use Unbehagen's ZDF-Mediathek plugin. So i added a few hacks in order to get it running. All the changes should be backward compatible, so that it should still be running on the good old Xbox.
Since i could't find the maintainer's email address, i post the changes here and hope that the changes will perhaps be integrated. Feel free to contact me on any questions.
Here is my joox.plx file:
version=1
background=default
title=ZDF-Mediathek
type=rss
name=Die Mediathek vom ZDF
thumb=default
URL=http://www.zdf.de/ZDFmediathek/sendungen?view=navJson
Here is the patch to default.py
--- /home/gee/build/temp/plugins/video/ZDF mediathek/default.py    2008-05-02 15:44:08.732169984 +0200
+++ default.py    2008-05-02 15:46:28.036577952 +0200
@@ -4,8 +4,8 @@
from string import *
+from ntpath import pathsep
import codecs
import xbmcplugin
import sys, os.path
@@ -14,13 +14,16 @@
import xbmc, xbmcgui
import re, os, time, datetime, traceback
import htmlentitydefs
Version='1' #program version
SubVersion='3'
RootDir = os.getcwd()
-if RootDir[-1]==';': RootDir=RootDir[0:-1]
-if RootDir[-1]!='\\': RootDir=RootDir+'\\'
-cacheDir = RootDir + "\\cache\\"
+if RootDir[-1]==';':
+    RootDir = RootDir[0:-1]
+RootDir = RootDir + os.path.sep
+cacheDir = RootDir + "cache" + os.path.sep
def decode3(line):
         dic=htmlentitydefs.name2codepoint
@@ -101,30 +104,10 @@
                 self.localfile = URL
                 self.state = 0 #success
         else: #assuming relative path
-                self.localfile = RootDir + '\\' + URL
+                self.localfile = RootDir + URL.strip()
-#    def load2(self, URL, localfile):
-#        print URL
-#        if URL[:4] == 'http':
-#            try:
-#                loc = urllib1.URLopener()
-#                loc.retrieve(URL, localfile)
-#            except IOError:
-#                traceback.print_exc(file=sys.stdout)
-#                self.state = -1 #failed
-#                return
-#            self.state = 0 #success
-#            self.localfile = localfile
-#        elif URL[1] == ':': #abolsute path
-#            self.localfile = URL
-#        else: #assuming relative path
-#            self.localfile = RootDir + '\\' + URL
# Description: Playlist class. Contains CMediaItem objects
@@ -350,7 +333,7 @@
             self.state_busy = 1
            #load the playlist
-            ext = self.getFileEntension(URL)
+            ext = self.getFileExtension(URL)
             if ext == 'plx':
                 result = self.playlist.load_plx(URL)
             else: #assume rss feed
@@ -469,10 +452,10 @@
         # Parameters : filename=local path + file name
         # Return     : -
-        def getFileEntension(self, filename):
+        def getFileExtension(self, filename):
             ext_pos = filename.rfind('.') #find last '.' in the string
             if ext_pos != -1:
-                return filename[ext_pos+1:]
+                return filename[ext_pos+1:].strip()
             else:
                 return ''
@@ -526,8 +509,6 @@
                     dialog = xbmcgui.Dialog()
                     dialog.ok("Error", "Error running script.\n\nReason:\n"+str(e))
win = Main()
win.run()
cheers
GeE
nice, i will try it....
