Installed 'repository.marcelveldt-1.0.2.zip', now getting skin installation failure message, no idea why?
Is there a list of which addons I need to install from 'repository.marcelveldt-1.0.2.zip' before installing the skin?
JanM201
I thought I had that fixed with the time and temp...I'll take a look.
I can take a look at adding those cases to Low List, but it might take a while before I can get to it.
Jeffers24
Can you post a copy of your log? It should show what the problem is.
Jeffers24
Try removing the subfolders from "addons/temp", remove the skin file from "addons/packages", and remove the folder skin.aeonmq7.leia.mod from "addons" (if it exists) and try to download/install the skin again.
(2020-03-26, 16:32)latts9923 Wrote: [ -> ]@Jeffers24
Got the same error message.
Skin installation got to around 99%, then went back to 92%, then failed.
Log is here:-
https://paste.kodi.tv/zehahohuya
This is what was in my temp folder:-
Hi!
Do i need to still need to install original kodi leia. Or just download latts repo and install leia mod. Thank you.
(2020-03-28, 14:26)creeker Wrote: [ -> ]Hi!
You need to install Kodi first. The Mod is just an interface skin...
Yes, i know. I meant just the skins.
(2020-03-28, 18:59)creeker Wrote: [ -> ]Yes, i know. I meant just the skins.
Sorry, seemed your question was pretty specific but... . The first post in this thread provides clear instructions.
Jeffers24
If you would, enable debug logging, try installing again and paste the log. Thanks!
Smirnoff13
I can look at implementing that mod.
