Vimmelthevampire
I didn't think about the Skin Info Service Add-on causing the problem.
MB1968
Do you have that Add-on installed?
(2020-10-30, 13:56)latts9923 Wrote: [ -> ]@Vimmelthevampire
@MB1968
I'm sure I had it installed when I started with the MQ7 Leia mod. I always follow the install instructions precisley. But I must have removed it somewhere un time. When you go to System - Addons - Dependencies, Kodi reports that the Skin Info Service is orphaned. This is probably the reason I removed it a while ago.
I just reinstalled Skin Info Service. The Shelf3D views, work fine now. Thumbs up for pointing me in the right direction. The same counts for Vimmelthevampire.
Thanks for the update. Very nice additions! Just curious, why doesn't discart for boxsets work, when "center list" has been enabled? You'll probably have a good explanation for it, I guess.
MB1968
You betcha...and thanks!
The Movie Set Cases is only designed to work with Center List off. I can look at adding an option for that to work with Center List as well, but it will take some time.
MB1968
I’ve updated the Kodiflix code for Movie Set Cases to work with Center List. I also noticed that there was some code not working that displays the movie discart for sets when Movie Set Cases is disabled. This will all be included in the next update.
(2020-11-09, 15:12)latts9923 Wrote: [ -> ]@MB1968
Great news. I'm looking forward to the next update.
Hi @
latts9923
Thank you very much for the latest updates & all your hard work, making this skin looking fantastic.
Just a couple of things from my side.
Picture 1:
These discs used to spin, not anymore for some reason. Can you look into this.
Picture 2:
Would it be possible to give us an option to turn clearlogo on or off in the top left corner? We've got all the other art, why not add this as well to look even more awesome.
Picture 3:
Could you please move this icon down so it lines up with all the other icons on the bottom.
Thanks very much again
(2020-11-11, 16:34)latts9923 Wrote: [ -> ][*]You can now use "MOVIE SET CASES" in KodiFlix with Center List enabled. Thanks to MB1968 for the request!
Thanks for the update. It seems like the skinning season has opened with all the updates appearing so quickly
Movie Set Cases work fine with Center List enabled. Nice! However, I also prefer to enable Center Focus and Lower Info. Because there is downside when enabling Lower Info and not using Center Focus. At the line where the rating is displayed, there is not enough room to display the text for the number of movies and total duration for filmsets. Enabling Center Focus fixes this issue. But unfortunately the Movie Set Cases don't work with Center Focus enabled. There might be a good reason for this of course. (movie sets with 10 movies i.e. Star Wars?)
MB1968
You're welcome! Haha...yeah, with the weather turning colder my fishing time has been diminished, so more time for modding!
It took a lot to get Center List to work with Movie Set Cases. I can look at adding Center Focus at some point, but your are right it will only allow for a limited number of cases/discs to slide out.
(2020-11-13, 22:45)latts9923 Wrote: [ -> ]@MB1968
I can imagine it took a lot of time. The perspective from left to right has to be right, so I guess you had to test a lot to be sure the dimensions for all images were correct.
I have disabled "Lower Info" and I'm satisfied with the current skin version. Don't spend too much time on Movie Set Cases and Center Focus.
Any idea why the collection poster on CoreELEC is displayed twice. I copied the skin files from Android to CoreELEC, to be sure CoreELEC is using the same files.
MB1968
Yeah, if you look at the bottom of the xml for KodiFlix, I had to copy each image and adjust the code for Center List. There are two posters that show when Movie Set Cases is enabled. If you turn it off you should only see one. At the bottom of the KodiFlix xml look for "$VAR[ListPosterVar]". Like I said there are two of them now, so edit the second one that has "Skin.HasSetting(KodiFlixMoviesCenterList)" in the visible line. For some reason, it looks like CoreELEC is throwing the coordinates off a little. You'll have to move it left, down and maybe adjust the height...that poster was a pain in the butt to get it to look right with Center List.
(2020-11-14, 16:00)latts9923 Wrote: [ -> ]@MB1968
Thanks for sharing the pain in the butt
I'll try tomorrow.
