Angelinas
I tried the update you provided for script.module.metadatautils. I see the Top 250 info for all my Movies, but I still don't see the Top 250 info for TV Shows. What is strange is that I do see the Top 250 for TV Shows if I switch to the Titan Mod for Leia Skin. And I am using the same code as that skin...
xml:
<label>#$INFO[Window(Home).Property(SkinHelper.ListItem.IMDB.Top250)]</label>
(2021-01-15, 00:41)Angelinas Wrote: [ -> ] (2021-01-13, 20:04)MB1968 Wrote: [ -> ]This sounds like a mission impossible to fix it...
I removed the status for tv shows in the KodiFlixTV.xml file recently. Another peculiar issue that occurred spontaneously.
I think you will find this interesting...ImdbTop.250
https://forum.kodi.tv/showthread.php?tid...pid3003126
Thanks for the information. I followed every step, but unfortunately it did not make any difference.
MB1968
I tried my code on several other skins and it shows the TV Show Top 250 just fine. I just don't understand why it won't work on MQ 7 or MQ 8 either one.
(2021-01-16, 00:27)latts9923 Wrote: [ -> ]@MB1968
That's funny because it works on my Aeon MQ8 skin in WBMC (Kodi fork). I'm beginning to think that a particular combination of addons, is causing this behaviour.
You'll probably know which addons are involved, don't you? We could compare the version numbers we're both using (in MQ8) to narrow down the culprit.
EDIT: I deleted simplecache.db. The Top 250 ranking for tv show Dark is no longer visible.
I don't understand why you write same thing "imdb250 doesent work in this skin but working in other!"
AeonMQ7-Working.....good code for for almost all windows (widget missing all flags, for me.When have flag, then missing info for imdb2q50)
AeonMQ8-Working.....good code for for all windows
Yours problem is wrong simplecache.db...send me on pm your simplecache.db and kodi log.Time to end this story
TVShow view KodiFlixTV (from library)
DialogVideoInfo (for tvshow from content extended script)
Angelinas
I sent you a PM. What is so strange is that all the skins I've tested are on the same install of Kodi. Thanks for taking a look!
All of sudden the imdb 250 ranking is working again for tv shows...
I applied Angelina's fix and deleted simplecache.db. This seems to work for me, but not immediately.
MB1968
What in the world. I'm still scratching my head. I switch to the Titan Mod for Leia and I see the top250...switch back to MQ 7 or MQ 8 and I've got nothing.
The user @
Shredder_guitar came to me with an idea to auto update the Aeon MQ skin settings when holidays come around. We've been working on this for a while, and I think it's finally ready to release to everyone. Thanks to Shredder_guitar for the idea/contributions and @
robweber for the cronxbmc updates!
Cronxbmc
Scripts
Favorites
Thanks @
latts9923 I don't use holiday themes. But for those who do, it's a nice addition.
I let you know that the imdb 250 ranking for tv shows, is also working on CoreELEC again. I only had to wait a day. I assume this delay is caused by omdb api quota restictions.
MB1968
Hmm...it just will not work for me.
(2021-01-20, 16:25)VENTO25 Wrote: [ -> ] (2021-01-20, 14:32)latts9923 Wrote: [ -> ]@MB1968
The same for me.
Did you read message #2460 and opened the link for further instructions?
MB1968
Yeah, I tried that as well with no luck.
