(2021-04-29, 01:42)latts9923 Wrote: [ -> ]All,
Anyone else having problems with the Extra Fanart setting with Music? It only seems to be a problem with Leia...Krypton and Matrix is working fine.
It's working fine for me under Leia.
(2021-04-29, 01:42)latts9923 Wrote: [ -> ]@escoces1968
Do you have your APIs entered in the Metadata add-on?
All,
Anyone else having problems with the Extra Fanart setting with Music? It only seems to be a problem with Leia...Krypton and Matrix is working fine. I could have sworn this was working the last time I checked it...which was a few weeks ago.
Yes, I have it entered in the Metadata add-on. OMDB, TMDB and Fanart APIs.
Is possible get old versions (full, no updates) to test with them?
Thanks in advance.
MB1968
I don't know what the crap happened...it just quit working.
escoces1968
What version of metadatautils are you using?
(2021-05-01, 00:21)latts9923 Wrote: [ -> ]@MB1968
@escoces1968
Version 1.0.40
Author: Marcelveldt and others
(2021-05-01, 11:08)escoces1968 Wrote: [ -> ] (2021-05-01, 00:21)latts9923 Wrote: [ -> ]@MB1968
@escoces1968
Version 1.0.40
Hello, With the new update, all work fine.
Thanks a lot.
Is possible to add in the Showcase View the icons of Oscar Adwards like the Right List View. Instead top of cover (Right view) is better (Showcase View) left to IMDB #250, at top of view (but icons more little).
Thanks for this amazing skin.
latts9923
Thanks for the update.
1. The default LastFM tab works fine, but the Extended Info addon is still producing an error when I open the artist Dialog View window. Are you experiencing the same?
2. Please check message #2590. The recent skin update did not solve this issue.
3. For new artists I've recently added to the music library, I don't see an overview of their discography anymore.
4. I've update the Dutch language file for the MQ7 Leia mod. You can download it from my Dropbox folder:
https://www.dropbox.com/s/r0br65je91em63...gs.po?dl=0
MB1968
1. I fixed the other Extended Info error. It will be part of the next update.
2. I see the "HIDE LOGO FOR BOXSETS" button in the Top Menu for KodiFlix using the Leia Mod. It should be visible if you have Boxsets as the layout.
3. I've added a few new artists and it keeps displaying the album synopsis by default. I'll try adding the artist from your screenshot and see if I can reproduce the problem.
4. The Dutch file goes in the resource.language.nl_nl folder, right?
(2021-05-04, 03:00)latts9923 Wrote: [ -> ]@MB1968
1. Thanks.
2. It works fine for me in the MQ7 Matrix mod but not in Leia. Can you send me your .xml files (KodiFlix.xml, KodiFlixTV.xml, IncludesTopmenu.xml )that are needed for the Leia mod?
3. Strange
4. Correct. I'll send you the Dutch language file for the MQ7 Matrix mod also. You'll receive a PM.
MB1968
2. If you installed v1.0.4.2 you have the same files as I have. Look in IncludesTopMenu.xml for
id="17121". That's the radio button for Hide Logo.
4. Sounds good!
I downloaded the skin files again and I can see both toggles now in the topmenu. Not sure what went wrong on my side. I probably forgot to copy the new code to my custom IncludesTopmenu.xml. Not once,but twice. I feel stupid now....
MB1968
Glad you got it figured out! Don't sweat the small stuff bud. I've made the same mistake multiple times.
latts9923 I am using the View Showcase for movies. I think that in the last versions of the mod, the studios logo (at the left bottom of the view) is going to search online, not at .nfo file. In the info movie, the text is charged instantly, but the logo at bottom don't show if I don't have internet.
escoces1968
I'm having trouble with studios in Leia right now as well. The code for the studio has been the same for quite some time.
