Thanks! It's good to be home again...that was a long trip.
Thanks for the update. I think you've forgotten to include the ViewsKodiFlixTV.xml file that contains the changes for the studio icon.
MB1968
You bet bud! I didn't change anything in ViewsKodiFlixTV.xml. I changed the code for the variable "
value_studio_tv" in IncludesVariables.xml.
I see. The studio icons on the boxset behave normally now. But I prefer to see them in blank and white. They are coloured now.
MB1968
The studio icons are controlled by the
MEDIA FLAGS - ICONS setting in SKIN SETTINGS. I can change them to use the
SHOW COLOURED STUDIO ICON setting instead. Or would you rather have an independent setting for those?
latts9923,
Please check these images. My skin settings did not change. In version 1.0.4.5 I had coloured media icons and black and white studio icons for tv shows. After updating to version 1.0.4.6 I have coloured media icons and coloured studio icons.
Skin settings
Skin version 1.0.4.5
Skin version 1.0.4.6
MB1968
I've been messing with the settings for the KodiFlixTV Boxset studios. The only way I can get them to display correctly is to tie them to the MEDIA FLAGS - ICONS setting in SKIN SETTINGS.
(2021-11-27, 14:39)latts9923 Wrote: [ -> ]@MB1968
Okay, can you still make the combination coloured media icons and black and white studio icons like in version 1.0.4.5?
(I edited #2753)
MB1968
I've added a new button to the Top Menu for KodiFlixTV that will allow you to switch between the default and colored studio icons for Boxsets.
(2021-11-28, 15:48)latts9923 Wrote: [ -> ]@MB1968
Thanks for this addition.
Thanks for the update, for still maintaining the Leia mod and your kind support last year.
I'm experiencing some small issues with version 1.0.4.7 but will report them later. Enjoy Christmas and your holiday.
Cheers buddy
