MB1968 Wrote: [ -> ]Thanks for the update!
You're welcome!
MB1968 Wrote: [ -> ]What a nice addition! I'm seeing a blank space in the media icons bar for moviesets. Is it for the MPAA icon?
EDIT: It's for the aspect ratio. It's not visible on my system. Metadata addon 1.0.43 has been installed.
Thanks! It took some work to get that to work and look right, but I really like how it turned out! You will need to rebuild your simplecache database after installing the latest Metadata update.
MB1968 Wrote: [ -> ]Only the upper part of the Premiered" label is visible. Have you noticed that? I think the height of the text field is not correct.
I see the entire Premiered label. Can you post a screenshot?
MB1968 Wrote: [ -> ]The text is still scrolling for tv shows with a lot of ratings.
Doh! K...I'll make it even wider.
MB1968 Wrote: [ -> ]I think you have forgotten to apply this change for the Leia mod. I'm still seeing the TV Show title.
Well crap! I meant to make that change to Leia first, and I ended up making the change to every skin version EXCEPT Leia! LOL
MB1968 Wrote: [ -> ]I noticed that you've uploaded new resource images addons to the Leia directory on your website. Are you sure we need these for the Leia mod?
https://holybid.com/kodi/lattsrepo/maste...tras.color
https://holybid.com/kodi/lattsrepo/maste...atio.color
https://holybid.com/kodi/lattsrepo/maste...odec.color
These Add-ons are just for the MQ8 skin.
latts9923 Wrote: [ -> ]Thanks! It took some work to get that to work and look right, but I really like how it turned out! You will need to rebuild your simplecache database after installing the latest Metadata update.
Yes, that worked. Thanks. The Matrix Leia mod shows the aspect ratio without having to delete simplecache.db first.
latts9923 Wrote: [ -> ]I see the entire Premiered label. Can you post a screenshot?
I'll do later today. I'll edit this message.
EDIT
latts9923 Wrote: [ -> ]Doh! K...I'll make it even wider.
Nice!
latts9923 Wrote: [ -> ]Well crap! I meant to make that change to Leia first, and I ended up making the change to every skin version EXCEPT Leia! LOL.
Can happen with so many mods to maintain. Unfortunately the widgets on the MQ8 skin load so slowly under Android. Therefore I still prefer to use the MQ7 mods
latts9923 Wrote: [ -> ]These Add-ons are just for the MQ8 skin.
Clear.
Just a FYI for any Leia or Krypton users with the recently broken Yahoo! Weather addon. There is a fix available. To apply manually see
this post. To install from repo see
this post.
Thanks for the info. I'm using the Open Weather addon. There probably was a similar issue with Open Weather last week under Matrix. But the Open Weather addon was updated quickly and works fine again.
(I'll answer your latest PM today)
MB1968
I'll see if I can reproduce your problem with the Premiered label. This might be one of those "only on Android" problems.
latts9923
Regarding the implantation of Rotten Tomato and Metacritic ratings for TV shows. Only the shows that I have manually added those rating to the nfo files are displaying them. Is that how it is supposed to be?
Juan Mortyme
I've had mixed results with Skin Helper displaying TV show rating info. The info is out there, but some display and some don't...it's really random. I'm not sure yet how to get everything populated without an NFO file.
(2022-02-17, 15:11)latts9923 Wrote: [ -> ]@Juan Mortyme
What we need is an add-on that does this job. It's nice if you can see the RT ratings, but for new tv shows, the rating in Kodi is already outdated once you add the series. After all, new reviews/ratings are added every day.
Fare enough. The RT website itself is inconsistent when it comes to TV series.
Insert Trakt info for tvShow...shs populate this info online
(2022-02-11, 22:09)MB1968 Wrote: [ -> ]Have you tried short names? I mean clearlogo.png instead of moviecollectiontitle-clearlogo.png.
MB1968 I tried. The MANAGE > CHOOSE ART >>ADD ART TYPE for the missing arts did the job.
latts9923, please go to your music library. Select an artist that has at least 2 albums.
Go to the album view.
Press I
Check the bottom bar, check the album title
Go back and select the 2nd album
Press I
What do you see?
In the information window, two tabs have lost their main functionality: showing images
- LastFM Top
- Similar Artist
I would like to delete these tabs. But I can imagine other users prefer to keep them. Can you advise me where to delete the code?
MB1968
Yup, I too see what you are seeing.
MB1968
Juan Mortyme
I removed the Last.fm Album label from Music Info if Albums are being viewed. I also removed the Last.FM Top and Similar Artist buttons as that info is no longer being provided by the API.
