clark_from_austria
The forum was reorganized some time back. Skins that are not available on the KODI repo or that are no longer supported were moved to Skin Archive.
Bladerunner1962
I was just searching your problem and noticed that Wanilton helped you on another site. Are you good to go now?
I am sorry to ask this here but I can't find the files or answers.
What is Kodiflix and KodiflixTV?
If these are addons or such .........where are they available from?
Thank you...........
Hello, I may have discovered a bug.
Disc path for custom disc art -Video and Audio
It is possible to change, now but I have to change a couple of times and restart kodi a couple of times to get the covers I want.
It's better since the last update before it was impossible to change.
melons2
Hi there views that you can select within kodi (like Right List and Showcase and so on)
melons2
KodiFlix and KodiFlixTV are views available from the Top Menu to use for Movies and TV Shows.
Bruce_Banner
If you bring up the context menu on an album, select Artwork Options and then Manual configure artwork you can select which artwork to change and browse for an image. On mine I have to escape out of the first list and then discart appears in the second list.
wints
If you're asking how to change/enable views, if you access the Top Menu, up arrow twice to open the (DE)ACTIVATE VIEWS page.
Hi ladds9923,
regarding the number of albums shown in the album view:
I wonder if it's a kodi or a skin issue, that the number is wrong (to low) although all albums are shown. I took a look in the album table and there are 35 more. I think that the album titles are counted, so all albums named for example "Greatest Hits" are only counted as one?
Other things:
Quote:Per abress's request, I added code to the Right List music view that will display the local discart first if available. If not, it will use the Skin Helper Service to display the discart. There is also a new button in the Top Menu to enable/disable the discart.
This still doesn't work for me. Of course I have no cdart when button is disabled, but I still don't see my own local cdart when it is enabled, but nothing or only downloaded "foreign" cdarts.
I wonder which is the xml file where I can alter some thing in the bottom part of the album/song-rightview (deleting themes and mood, change codec font and now playing font, change rating to 5stars system instead 10stars)?
Although I have enabled Music as Startup-Window is always kodi always starts with TV series?
(2018-12-06, 14:30)latts9923 Wrote: [ -> ]@wints
Hi latts, no I wasn't asking how to change views I was attempting to explain to @
melons2 what KodiFlix and KodiFlixTV where
wints
Oh...duh. I see where you have his name above the comment now. Haha.
abress
I'm not sure I follow you on the album count question. Are you not seeing all of your albums? I don't have my entire music library loaded, so someone else may have to chime in if you're seeing the same problem.
For you local discart to display after you select it, you may have to remove your Textures13.db file as well as your folders under Thumbnails.
There are multiple xml files you have to edit to accomplish what you want.
There's a bug with the horizontal menu displaying the correct menu item on startup. So far I've been unable to fix it.
(2018-12-05, 15:02)latts9923 Wrote: [ -> ]@clark_from_austria
@Bladerunner1962
Yes, thats right :-) Wanilton helped me very fast.
Unfortunately I have new/further errors/crash again and again then using MQ 7 Leia Mod on my Nvidia Shield.
I used this skin for so long time under Windows without any problems.
My errors refers to missing addons, wrong scripts and so on (e.g. missing joystick links/parings...I don't use no joysticks).
I see nearlly on each Kodi start new/other errors.
Either Kodi crashs using MQ 7 on the Shields direct on/after start or crashs after some seconds or minutes.
If I use the normal/standard skin of Kodi 18 (Leia rc1 or rc2), I have no problems.
I also use only the standard given addons of Kodi. So there could be an impact, using e.g. addons, which could causes problems.
Is a CLEAN version of MQ 7 for Kodi 18/Android/Shield available?
CLEAN means: only normal/standard Kodi functions
>>> I don't play games in Kodi, don't use joysticks, don't use TV functions, don't use streaming portals (like Youtube).
I know, that all the things are in all the XMLs. But, I have not enough knowledge to CLEAN all the XMLs on my own.
(2018-12-06, 14:28)latts9923 Wrote: [ -> ]@Bruce_Banner
Thanks. Very good job you do with this skin.
latts9923 Is it possible to have List3d for content (mp3s)? List3d is working for artists, albums etc but not for the files in the albums. Will post a screenshot later if you need one.
