(2019-02-14, 03:53)the_bo Wrote: [ -> ]Can't remember on top of my head but I believe it may be called MyMenuNavigation.xml
or NavigationBar.xml or something with navigation in the XML name.
Found it.. it's in MyVideoNav.xml line 500 / 501 |
https://i.imgur.com/dBt9FHP.jpg
(2019-02-14, 14:02)koldtoft Wrote: [ -> ] (2019-02-14, 03:53)the_bo Wrote: [ -> ]Can't remember on top of my head but I believe it may be called MyMenuNavigation.xml
Found it.. it's in MyVideoNav.xml line 500 / 501 | https://i.imgur.com/dBt9FHP.jpg
Yeah that's it. Great work
(2019-02-14, 05:28)latts9923 Wrote: [ -> ]@the_bo
Thanks for the info on the skin reload! I've just been switching to a different skin and then back to MQ 7 to test changes.
Your welcome. Should make skinning much quicker now.
I should of posted this tutorial years earlier would of saved you some time switching skins and back lol
Looking forward to the next update cheers
Hello EveryOne !!
I found two ways for play trailers movies :
- contextmenu "play trailer" => launch the trailer from youtube (like skin estuary), that's work fine!
- "trailer" via button on informationbox => open a page tmdb with many video, the trailer is not in my language, many issues, ...
My question, is it possible to launch trailers by youtube (like estuary) when i click on button "trailer" of informationDialog?
Changing the width of the Fadelabel in the showcase view
My text is overlapping the plot description, when the country, genre, Director, Studios or Duration text becomes too long.
I found the code for controlling them in ViewsShowCase.xml around line 2030
They look like this
xml:
<control type="label">
<include>ShowCaseLabel_Extrathumbs</include>
<top>156</top>
<label>$VAR[value_ground1_label]</label>
</control>
<control type="fadelabel">
<include>ShowCaseValue_Extrathumbs</include>
<top>180</top>
<label>$VAR[value_ground1_value]</label>
</control>
But I can't figure out how to sex a max with or max chrars or something like that to fix this issue. i tried addin width="10" to the label tag (html style) and I tried adding a <width> tag. But after that I am pretty much out of ideas.
@latts9923 I have a strange bug
Where if I am in the ViewsShowCase view for movies, and I go to the DialogVideoInfo view and click "view trailer". It then goes to the select trailer video view (which i love btw) but then once I select/watch a trailer or just go back from there, it returns me to my movies in the RightList view. It then stays in that view, until i manually switch back to ShowCase
Example:
1. Select a movie in the ShowCase view (selecting Terminator 2 becaus it's so awesome)
2. Then in the DialogVideoInfo i click trailer
3) Then once I get to the trailer screen I can pick a trailer (or just click back twice)
4) And it will return me to the RightList view
I think I found another bug @
latts9923
The Download subtitles overlay is missing a background (or something like that) so you can see other stuff behind it, making it really hard to read the subtitles
koldtoft
The width tag should be in the fadelabels and not the label. Try this. Do the same for rest of fadelabels. Can set scroll to true/false to your liking.
xml:
<top>180</top>
<width>60</width>
<scroll>true</scroll>
</control>
For the subtitle dialog i believe another user reported this bug awhile back. Latts is looking into it.
(2019-02-14, 17:37)the_bo Wrote: [ -> ]The width tag should be in the fadelabels and not the label.
Yes.. for some strange reason, that does nothing. I know I am at the right place because I can move them around and stuff.
the_bo ' Wrote: [ -> ]For the subtitle dialog i believe another user reported this bug awhile back. Latts is looking into it.
Correct, I did. Will be fixed next update.
I just finished recording the video to go along with the next update. I hope to have it available Friday evening or sometime on Saturday.
Wanted to share a quick video update of my styling progress. To be continued...
I am still having problems with the width of the fadelabels but I am sure I will figure that out
- Have (in my opinion) improved a bit on the constantly spinning CD that I did not like
- Changed the styling of RT and IMDB scores slightly
- Added Oscars in the top for Oscar nominated and winning movies
- Finally fixed the clearlogo size in the ShowCase view.
- Changed the buttons/options to suit my need and changed the order a bit
Ps. Can't wait to see next update for MQ 7 (hopefully) tomorrow (fingers crossed for the "snapping" issue being fixed when scrolling through movies on ShowCase view.)
