koldtoft
I've been working hard on the next update, so I'm trying to catch up on some of these conversations. On your Showcase fadelabel width, it is controlled by the include "ShowCaseValue_Extrathumbs" that is in ViewsShowCase.xml. By default the width is set to "472" and I don't see an overlap on mine.
Also, I believe I fixed the "snapping" problem with the view when "STACKED" is enabled. Find all your animation times that are set to "210" and change them to "400". I'll include this in the next update since I've already completed the update I'm trying to get out.
Thank you very much @
latts9923
All your hard work is greatly appreciated. Can't wait to see the next update
Edit:
Found it.. it was set to 944 for some reason. Maybe I changed it by mistake.
Edit2:
Changing the animation time from 210 to 400 does not fix the snapping issue for me
I changed it 12 places in ViewsShowCase.xml
latts9923 in the Shelf3Dviews the tracklist on the left side of the screen starts to scroll almost immediately. A couple of weeks ago I requested to extend the time duration before the tracklist starts to scroll. Three seconds or so before the list starts to scroll is more convenient. It wasn't implemented in the last update. I'll hope you're willing to do so in the upcoming update.
MB1968
Hey bud. I've already "locked" the update since I'm about to post it. I'll take a look and let you know what to change until I can get another update posted.
koldtoft
You're welcome!
What system are you running Leia on? I changed the time to 400 on Krypton and Leia and the animation looks much better on both.
You made a certain view far too transparent in the latest update. It shows up when you are notified that you are installing dependencies for an add-on, or when selecting artwork. Perhaps elsewhere as well. Makes it very hard to read.
https://www.dropbox.com/s/ftorq8omoch2vl...1.png?dl=0
Hi, Thanks for the work on MQ7 for Leia
I have 2 questions that maybe I can have help with.
First: I recently have an Nvidia shield and have setup Kodi using the 1.0.14 version but it does not "auto update" to 1.0.15
is the update process only to install the 1.0.15 .ZIP file manually?
Second: I think this one is a bug, With the kiosk modes turned on pushing the up button on the main menu still brings up the "flexible widget" selection screen, I think the widget selection should be locked out when kiosk modes are turned on? Or maybe I am missing an option somewhere else to disable this!
Again, thanks for the work
desepticon
What steps did you take to get the Choose Art window to display on the movie view? I have been unable to reproduce that. The Choose Art window always looks like this for me...
The same background appears for dependencies as well.
anotheraeonuser
You're welcome!
For now the update is a manual affair. I'm still trying to get the Skin to update via my Repo. It downloads and begins the install, but then ends up failing every time.
I'm not aware of a setting to disable the Flexible Widgets in Kiosk Mode. I'll see what I can do.
Thanks for the quick reply, i'll perform the manual update.
I was only concerned that if I did a manual update it may reset the skin to default settings which may lead to much adjusting settings to get it perfect again
anotheraeonuser
You betcha. No, you won't lose any of your settings if you manually install the update file. The update will actually add a few new settings to settings.xml.
latts9923
I got there by bringing the context menu up on a film, and selecting "Get Artwork - GUI Mode". Incidentally, this doesn't actually work when trying to select an artwork. Nothing gets changed. The same transparent background also occurs though when going to the information page, and selecting "Choose Art". This mode actually does work. I also got the transparent view when installing a new add-on, and being informed that it is installing dependencies (not the dependency view itself in the add-on section of settings).
(2019-02-16, 03:32)latts9923 Wrote: [ -> ]@MB1968
No problem. I'll wait patiently for your instructions to tweak the xml file.
Thanks a lot for the update. We keep you busy, don't we? Time to take a step back.
Hi @
latts9923 - Thanks to your video I was able make fanart finally work in 1.0.1.5
! Awesome! Again - BIG thanks!
I have a few quick questions please if you have the time -
Are you able to make (AB extra) fanart to work also in List 3D and List 3D v2 (in movies)?
Also - How should I name local logo files in music folders? Nothing I do (or set in Kodi\MQ7\AB) seems to work and display those. They're currently named clearlogo.png .
And last - Do you have a repository with this skin in it you can share (or have I missed it?)?
Appreciate your big work, help and support!
