Full Version: apt-get upgrade -> no more Kodi
I've had Kodi running great for many years. Today I was doing a bunch of housekeeping and decided to update, as I've done a couple times over the years.  I ran:
apt-get update
apt-get upgrade
apt-get dist-upgrade
apt-get autoremove
The last two steps were new to me but recommended on a linux blog. I rebooted and now Kodi won't start. Shame on me for haphazardly upgrading but I'm always up for learning how to fix my dumb mistakes.  My kodi.log shows:
KodiLog:
 ERROR: X11 Error: No Display found
 FATAL: CApplication::Create: Unable to init windowing system
Here are the last few lines of syslog:
syslog:
Mar  5 23:09:32 MediaCenterXBMC kernel: [ 1053.817128] kodi.bin[3643]: segfault at 8 ip 00007f31a044c458 sp 00007ffff79f8600 error 4 in libstdc++.so.6.0.19[7f31a0391000+e6000]
Mar  5 23:09:34 MediaCenterXBMC kernel: [ 1056.037300] kodi.bin[3687]: segfault at 8 ip 00007f1fdcab0458 sp 00007fffd1ccf4e0 error 4 in libstdc++.so.6.0.19[7f1fdc9f5000+e6000]
Mar  5 23:09:37 MediaCenterXBMC kernel: [ 1058.281078] kodi.bin[3731]: segfault at 8 ip 00007f584853c458 sp 00007ffffda1ced0 error 4 in libstdc++.so.6.0.19[7f5848481000+e6000]
Mar  5 23:09:39 MediaCenterXBMC kernel: [ 1060.406828] mtrr: no MTRR for d1000000,e00000 found
Mar  5 23:12:52 MediaCenterXBMC kernel: [ 1253.972029] usb 2-2: reset high-speed USB device number 2 using ehci-pci
Mar  5 23:12:54 MediaCenterXBMC kernel: [ 1256.060593] kodi.bin[4096]: segfault at 8 ip 00007fa50fe2c458 sp 00007fff4ca2adc0 error 4 in libstdc++.so.6.0.19[7fa50fd71000+e6000]
Mar  5 23:12:56 MediaCenterXBMC kernel: [ 1258.223647] kodi.bin[4140]: segfault at 8 ip 00007fc8e2fdd458 sp 00007fff4df488f0 error 4 in libstdc++.so.6.0.19[7fc8e2f22000+e6000]
Mar  5 23:12:59 MediaCenterXBMC kernel: [ 1260.428416] kodi.bin[4186]: segfault at 8 ip 00007f50c2e1b458 sp 00007fffeed9b800 error 4 in libstdc++.so.6.0.19[7f50c2d60000+e6000]
Mar  5 23:13:01 MediaCenterXBMC kernel: [ 1262.542720] mtrr: no MTRR for d1000000,e00000 found
Mar  5 23:16:18 MediaCenterXBMC kernel: [ 1460.077197] kodi.bin[4520]: segfault at 8 ip 00007f65a09e7458 sp 00007fffe5414940 error 4 in libstdc++.so.6.0.19[7f65a092c000+e6000]
Mar  5 23:16:21 MediaCenterXBMC kernel: [ 1462.278313] kodi.bin[4565]: segfault at 8 ip 00007faad524b458 sp 00007fffcacec780 error 4 in libstdc++.so.6.0.19[7faad5190000+e6000]
Mar  5 23:16:23 MediaCenterXBMC kernel: [ 1464.521153] kodi.bin[4609]: segfault at 8 ip 00007fee3e026458 sp 00007fff0c41eea0 error 4 in libstdc++.so.6.0.19[7fee3df6b000+e6000]
Mar  5 23:16:25 MediaCenterXBMC kernel: [ 1466.843438] mtrr: no MTRR for d1000000,e00000 found
Mar  5 23:17:01 MediaCenterXBMC CRON[4738]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Mar  5 23:20:01 MediaCenterXBMC CRON[4781]: (smmsp) CMD (test -x /etc/init.d/sendmail && /usr/share/sendmail/sendmail cron-msp)
Mar  5 23:20:01 MediaCenterXBMC sm-msp-queue[4797]: My unqualified host name (MediaCenterXBMC) unknown; sleeping for retry
Mar  5 23:20:25 MediaCenterXBMC kernel: [ 1707.088034] usb 2-2: reset high-speed USB device number 2 using ehci-pci
Mar  5 23:21:01 MediaCenterXBMC sm-msp-queue[4797]: unable to qualify my own domain name (MediaCenterXBMC) -- using short name
Mar  5 23:22:42 MediaCenterXBMC console-kit-daemon[1739]: GLib-CRITICAL: Source ID 219 was not found when attempting to remove it
Mar  5 23:22:44 MediaCenterXBMC kernel: [ 1845.612914] kodi.bin[4852]: segfault at 7fe5d4e88920 ip 00007fe5d4e88920 sp 00007fff28d0cfc8 error 14
Any advice on how to proceed from here?
You didn't post full kodi log, but it seems that for some reason X11 won't start. Do you have any logs or observations from what happened when you did the 4 steps you mentioned above?
Could you please provide more details about your hw/sw setup and gpu? And at least some outputs to start with:
uname -a
cat /etc/issue
dpkg -l | pastebinit
Thanks for the reply!
I previously cross-posted to another forum.  More info (and resolution) here:
http://www.linuxforums.org/forum/ubuntu-...issue.html
Broken nvidia drivers - so then mark this thread solved.
