2018-03-06, 10:16
2018-03-06, 10:16
2018-03-09, 12:38
are you able to reproduce this?
according to the changes, we did not have changed anything from this area for 2.9.8...
2018-03-10, 12:24
(2018-03-09, 12:38)mlaggner Wrote: [ -> ]are you able to reproduce this?I thought rolling back to an older version had cleared this up (2.9.4) but it's happened again.
I leave TMM running all the time on my file server (never had any problems until recently). It seems to happen randomly, I leave the machine alone and everything looks fine, when I go back a few hours later, the titles are all missing.
2018-03-12, 10:29
2018-03-17, 13:18
I'm using TMM since two years or so. I start it when I need it. I use it to scarpe, nothing else. In all that time I've never seen something like that before - until today.
A restart of TMM did help. There's no hint in the logs between my last activity and the disappearing titles.
TMM 2.9.8 is the version, I use it since it's appearance. It's running on Windows 10, latest updates applied. All data is stored on a NAS. I was shuffling some folders around because I'm converting from ReiserFS to XFS currently. Beside that no hint why the titles disappeared out of sudden.
2018-03-17, 18:07
do you use some sort of remote desktop?
I know that there are issues with the microsoft rdp service and direct2d rendering
2018-03-17, 21:26
Funny you say that as I do RDP to my server daily. (Although this has been the case for years and I've not had an issue with TMM before).
2018-03-18, 09:43
See the FAQ https://github.com/tinyMediaManager/tiny...FAQ#errors
Maybe adding this jvm arg to extra.txt works for you
2018-03-18, 10:55
(2018-03-18, 09:43)mlaggner Wrote: [ -> ]See the FAQ https://github.com/tinyMediaManager/tiny...FAQ#errorsThanks for the tip, just added this and will see how it goes.
2018-03-20, 17:04
Added -Dsun.java2d.d3d=false to extras.txt and been running for a couple of days before it finally happened again today.
2018-03-21, 18:15
did you try v3?
the tree has been completely rewritten and maybe there is no more issue in v3 (which we focus now)
2018-04-15, 10:34
(2018-03-21, 18:15)mlaggner Wrote: [ -> ]did you try v3?Not tried v3 yet but will give it a go this weekend.
I have discovered what I think was triggering the issue I had though. It appears that everything is OK on my file server until I connect with my Surface Pro 4 (which alters the DPI scaling the during the RDP session due to the resolution of it's own screen). Once I disconnect that and re-connect from a PC/phone at 1920x1080 resolution, this is when the titles disappear. If I never connect via the Surface Pro (and this no DPI scaling is performed) the issue does not appear to occur.
Not sure if that helps anyone else.
