Full Version: Android Apps Menu on Shield TV?
I love the (Fuse)neue skin but I am using it on the Nvidia shield and cannot access my android apps. I was previously using Aeon Nox and with that skin you can set extra menu items for shortcuts to android apps such as BBC iPlayer, Netflix, Spotify etc.
Does anyone know how you can make a menu (or sub menu) item to allow you to run an android app? This saves having to come out of Kodi when you want to watch Netflix Amazon Prime.
That's why I added a favourites tab. I can flip to Amazon or YouTube quickly.
4 steps to add a new tab to the menu bar.
Click + on an existing submenu to create a new submenu, then rename it and link it to your Favourites.
Now anything you put in your Favourites is only 2 clicks away.
Job Done 😀
