Full Version: Kodi crashed on Ubuntu 17.10 on S912
Hello.
I've successfully installed kodi 17.3 from kodi-old (for xenial) on Ubuntu 17.10 on S912, but it got a lot of errors on startup:
GL: Error compiling vertex shader
Full kodi log:
https://pastebin.com/wyt66ms4
root@Khadas:~# apt-cache policy kodi
kodi:
  Installed: 2:17.3+dfsg1-3
  Candidate: 2:17.3+dfsg1-3
  Version table:
 *** 2:17.3+dfsg1-3 500
        500 http://ports.ubuntu.com/ubuntu-ports artful/universe arm64 Packages
        100 /var/lib/dpkg/status
     2:16.1~git20160425.1001-final-0xenial 500
        500 http://ppa.launchpad.net/team-xbmc/kodi-old/ubuntu xenial/main arm64 Packages
        500 http://ppa.launchpad.net/team-xbmc/kodi-old/ubuntu xenial/main armhf Packages
root@Khadas:~# apt-cache policy kodi-bin
kodi-bin:
  Version table:
root@Khadas:~# dpkg -l |grep kodi
ii  kodi                                  2:17.3+dfsg1-3                           arm64        Open Source Home Theatre (executable binaries)
ii  kodi-bin:arm64                        2:17.3+dfsg1-3                           arm64        Open Source Home Theatre (architecture-dependent files)
ii  kodi-data                             2:17.3+dfsg1-3                           all          Open Source Home Theatre (arch-independent data package)
ii  kodi-visualization-spectrum:arm64     1.1.1-1ubuntu2                           arm64        Spectrum visualizer addon for Kodi
root@Khadas:~#
Commands
sudo apt-get install --reinstall kodi kodi-bin
rm -rf ~/.kodi
didn't solved the problem.
Can you tell me, how to fix that?
Thank you!
I strongly suggest looking into libreelec, which has several builds for s912 boxes.
Hi! Thank you for your answer Smile.
Yep, I am on https://forum.libreelec.tv/thread/5848-8...-for-s912/ now, but author of the distrib discontinued devepment.
So, I decided to start Kodi on Linux (I am using balbes150's ubuntu_mate_17_04_3.14_20171216.img.xz from https://yadi.sk/d/srrtn6kpnsKz2/Linux ) on my Beelink GT1 Ultimate TV box. I've updated the distrib upto 17.10 with do-release-upgrade, added http://ports.ubuntu.com/ubuntu-ports/ to the apt sources.list , updated system with apt update; apt-upgrade.
Kodi installed, but looks like I need some OpenGL driver. In the Libreelec kszaq made it via some "These builds use libhybris and Android gralloc Mali driver to provide OpenGL for Kodi". I don't know now, how he have done it and how to port that to the "my" Ubuntu artful distributive.
Am I correct about drivers?
Sorry you are way above my knowledge level!
this is not going to work. You need a kodi built specifically for AML devices, which your debian build for x86 is not.
read the forum thread carefully:
Only the development of the KODI17 version is discontinued (LibreELEC 8.2), because it's stable and KODI18 (LibreELEC 9.0) is on the way and it would be a waste of time to patch the old version and in a few weeks/month start testing again in the new version. Developers of the different amlogic branches even have joined their forces, so I would say the future for at least LibreELEC 9 on your S912 device is secure.
If you want a new hobby or don't like LibreELEC then you can try to use KODI on an ARM Ubuntu and despair of the Mali drivers, but otherwise I would recommend using the stable version under https://forum.libreelec.tv/thread/5848-8...-for-s912/ or if you want an instable and bleeding edge version then try to use the in development version https://forum.libreelec.tv/thread/10301-...2-devices/
