2018-03-12, 11:25
I've used kodi for many years, starting out with an actual Xbox1. When i initially migrated to PC, i retained the Xbox1 IR eye and remote, as i had it and it did everything i needed. Kept everything familiar for other family users too.
Some years later I bought a nice AVR which has a multi-device remote, and that remote can emulate the Xbox1 DVD remote, so now i have one remote to control all my kit. This is super convenient. I select the PC input on the remote, the AVR switches to the PC input, and the remote switches to emulate the Xbox functions.
However the Xbox1 IR eye seems for whatever reason to be unsupported in the normal linux/lirc builds. This means it needs various patches and messing around every time i update the OS. As time goes on, these patches are getting more and more complex, the patch hasnt been updated in eons and no longer builds cleanly against newer kernels. I've managed to limp it along, and its currently running fine against kernel 4.8.
But it leaves a dilemma. I want an updated system running the latest bugfixes etc, but at the same time i hate touching it because any time i do update it, it ends up broken and i have to spend ages fixing the remote.
So i'd like some advice. I want a replacement for the Xbox1 Eye, which Just Works. The default approach seems to be the "MCE" Remotes, but whatever i buy needs to be able to work with the existing AVR remote, rather than being forced to use a supplied unit.
Anyone have any recommendations?
