Starting yesterday when I try and open Kodi opens and then closes or kicks me out after about a minute. Has anyone else had problems with it - I have Krypton 17.6
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
Hard to tech, suggest a reinstall. Best of luck. If the problem persists, look towards freeing up some memory.
